STD Tuning Engine fuel pump pressure
fuel pump pressure
fuel pump pressure
Hercules
06-30-2011, 02:27 PM #1
Decided to ck. lift pump pressure,was 10lbs,but gauge was oscillating between 0-10lbs almost too fast to read. pressure gauge is good and of good quality. decided to install older check valve in pump and stretch spring to 22mm and book says 26-27mm, pressure now 30lbs still oscillating. 0-30. tested check valves in lift pump both sides work well section side holds vacuum pressure side holds pressure made this test at outlet and inlet of pump. volume on pump is also good, springs on check valves stretched a small amount. checked dead end pressure of pump 65lbs still oscillating between 0-65. any ideas why it is oscillating so greatly?? car runs well and always did. thanks.
Hercules
06-30-2011, 02:28 PM #2
Sucking in air?
Sucking in air?
06-30-2011, 03:07 PM #3
Don't sweat it. It's normal, that's way it pumps with the oscillation. Good you got the pressure up though.
Hercules
06-30-2011, 04:42 PM #4
Thanks,Thought it might be normal,others experiences very helpful,book is of no help on this. by the way ,have noticed some over all performance increase. Older ck. valve very cheap at local yards.
Hercules
dieselboy
Rotatin 5500 times a minute
680
06-30-2011, 04:47 PM #5
What's the spec?
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
What's the spec?
-Jesse
70 f250 390
66 Volvo amazon
Hercules
06-30-2011, 04:54 PM #6
20lbs,measured between filter and inj.pump.
Hercules
07-01-2011, 02:26 AM #7
You stretched uour spring to 22 when spec was 26-27?
Hercules
07-01-2011, 03:29 AM #8
Yes, 22mm gave 30lbs pressure,this was stretching spring about 4mm,easy to stretch hard to undo without cutting spring.
Just got the impression that stretching the spring that much would be too much,glad i listened . Checked pressure two places
four diff.times after venting (bleeding) system,pressure same.
Hercules
07-01-2011, 02:58 PM #9
Where IS the spring?
07-01-2011, 03:48 PM #10
It's located between the IP and engine block on the banjo of the hard plastic return line.
07-02-2011, 02:19 AM #11
Checking Fuel Pump and Bypass Valve procedure.
richclan
07-02-2011, 01:50 PM #12
if i stretch spring to 26-27mm could it create too much fuel pressure and if it did what would go wrong/break.
i dont have a pressure gauge so i dont want to create a problem
tks
richclan
tks
07-02-2011, 03:42 PM #13
(07-02-2011, 01:50 PM)richclan if i stretch spring to 26-27mm could it create too much fuel pressure and if it did what would go wrong/break.
tks
Yes it can. Most springs I pulled are around 20mm and a little stretch can bring the pressure up. I don't know how Mercedes came with that spec.
You can stretch it 1 mm at a time and see what each results are, just don't go over board. In the end you really ought to do it with a gauge.. Namely a glycerin filled gauge to counter act the oscillation which can be so severe you can't read the gauge.
This post was last modified: 07-02-2011, 04:05 PM by DeliveryValve.
tks
mr_manny
Diesel Offroad Club
91
07-03-2011, 12:50 AM #14
(07-01-2011, 03:48 PM)DeliveryValve It's located between the IP and engine block on the banjo of the hard plastic return line.
Just checked my IP, and my bolt looks like a regular banjo bolt....what's with that?
mr_manny
mr_manny
Diesel Offroad Club
91
07-03-2011, 08:18 AM #15
I can see a spring inside, but don't see how it would be possible to remove...let alone re-install.
[Image: IMG_20110703_061252.jpg]
guess I have a newer check valve Sad
This post was last modified: 07-03-2011, 08:25 AM by mr_manny.
mr_manny
Alastair E
Moderator?--Nah...
266
07-03-2011, 01:36 PM #16
Thats the later type--NON Adjustable....
Only the Older type are adjustable--They have a hex-head on the back end of the main head to unscrew...
[Image: 300TDnoplate.jpg]
Alastair E
mr_manny
Diesel Offroad Club
91
07-03-2011, 04:14 PM #17
(07-03-2011, 01:36 PM)Alastair E Thats the later type--NON Adjustable....
not fair Sad
mr_manny
not fair Sad
mr_manny
Diesel Offroad Club
91
07-04-2011, 12:30 AM #18
What If something was added to create additional back pressure?
Wondering if the higher back-pressure would achieve the same results, as extending the spring...
Any fellow later-banjo owners try this?
mr_manny
dieselboy
680
07-04-2011, 01:15 AM #19
You want a adjustable one? I think I have a few.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
07-04-2011, 04:49 AM #20
(07-04-2011, 01:15 AM)dieselboy You want a adjustable one? I think I have a few.
I need this too Confused
hansebanger77
mr_manny
Diesel Offroad Club
91
07-04-2011, 10:45 AM #21
would be sweet..let me know how much Smile
manny
mr_manny
manny
mr_manny
Diesel Offroad Club
91
07-05-2011, 02:40 PM #22
Was wondering, has anyone plumped an analog pressure gauge under the hood?
Being able to verify fuel pressure with only a glance, seems like a good thing to me Smile
mr_manny
07-05-2011, 03:25 PM #23
(07-05-2011, 02:40 PM)mr_manny Was wondering, has anyone plumped an analog pressure gauge under the hood?
You mean keeping it under the hood? That would be fine.
But putting it in the cabin, some manufactures think the pressure is too great to put it in the cabin and may cause injury if something goes wrong.
Here are a couple gauges that should work.
http://www.summitracing.com/parts/FRA-900004/?rtype=10
http://www.jegs.com/i/Auto+Meter/105/5412/10002/-1
mr_manny
Diesel Offroad Club
91
07-05-2011, 07:19 PM #24
(07-01-2011, 03:29 AM)Hercules Yes, 22mm gave 30lbs pressure,this was stretching spring about 4mm,easy to stretch hard to undo without cutting spring.
I did a quick google conversion, and 30lbs pressure seems much higher then stated specifications.
[Image: fuel.jpg]
0.6 bar = 8.7 psi
0.8 bar = 11.6 psi
2.0 bar = 30.0 psi
I take it the higher pressure helps w/0-60 times? Smile
mr_manny
[Image: fuel.jpg]
0.6 bar = 8.7 psi
0.8 bar = 11.6 psi
2.0 bar = 30.0 psi
tomnik
07-05-2011, 11:40 PM #25
Hi,
the lift pump is the limiting factor to go higher than approx. 1.5-2 bar.
Easy to check: run the engine at idle and close the return line from the IP back into the filter with a vice grip and check the pressure between filter and pump (supply side).
When the pressure increases the over flow valve at the IP return side could be better (and you will notice that the engine idles more quiet).
If the pressure stays the same then the valve is o.k. and the lift pump is already at its max.
I am working on 2.5 - 2 bar under all conditions.
The easiest way is to change the spring in the lift pump.
Tom
tomnik
Hi,
Tom
mr_manny
Diesel Offroad Club
91
07-05-2011, 11:53 PM #26
Good info...will try this test once I have a gauge installed.
thanks Tom.
mr_manny
thanks Tom.
07-06-2011, 12:21 AM #27
Delivery Valve is my hero
Hercules
07-06-2011, 01:20 AM #28
What fuel pressure would be too much ?? Mbz said stretch spring 26-27mm I stopped at 22mm. Well not the first time had to redo a repair following mbz instructions! Will leave at present setting,A stretched spring will ,decrease in tension 20% +/- very soon,undampened gauge bounces several lbs.higher,will end up having lower pressure. The higher pressure did improve performance over all speeds ,Just much more fun to drive. I would how ever suggest to stop at 20 lbs of fuel pressure so as not to over stress parts. (Good Day), is finding improved performance, with little money and time!!
Hercules
07-06-2011, 01:39 AM #29
How about adding shims under the spring to increase tension without stretching? Keep in mind I have not looked at one in front of me yet
This post was last modified: 07-06-2011, 01:39 AM by Captain America.
mr_manny
Diesel Offroad Club
91
07-07-2011, 10:29 PM #30
Stainless fuel pressure gauge arrived today.
[Image: IMG_20110707_201939.jpg]
Jesse is taking care of me w/an early design Adjustable Banjo Smile
looking forward to pluming this up, need to get more fittings...
This post was last modified: 07-07-2011, 10:51 PM by mr_manny.
mr_manny
