STD Tuning Engine Bosch M and Mw pump theory
300D50
Graphite Moderator, ala RBMK
07-03-2011, 01:35 PM #1
Please give your opinions.
https://docs.google.com/document/d/1QkAv...y=CJXuhs0I
Many thanks to OM616 for putting his time and effort into putting together 99%+ of the information in this document.
This post was last modified: 07-03-2011, 01:37 PM by 300D50.
300D50
Alastair E
Moderator?--Nah...
266
07-03-2011, 01:54 PM #2
Nice.....
But, Not enough about the 'M' pump specifically, for me!
We dont have the MW here at all as far as I know--Never seen one on M.B anyway!
[Image: 300TDnoplate.jpg]
Alastair E
Nice.....
300D50
07-03-2011, 01:57 PM #3
Well, the basics should swap over since it's mostly the governor in the doc right now.
If anyone wants to add to the doc, let me know and I'll add you to the edit list.
300D50
07-03-2011, 05:19 PM #4
Now thats some good stuff!!
300D50
07-03-2011, 05:23 PM #5
(07-03-2011, 05:19 PM)garage Now thats some good stuff!!
See, good things do come to those who wait!
There will be more added over time, but one of the big things we need is some non-copyrighted photo's of pump guts, since most the ones from the other thread were sort of "hot"...
300D50
Biohazard
Smokin like a champ!
376
07-03-2011, 09:40 PM #6
That is a great explanation of how the pump internals work! Turns out I was right, I didn't know crap about the guts of a pump. LOL I had gotten lucky when I pulled the rack limiter out of my MW and felt an increase. Also explains why some folks here didn't feel anything. Thank you for your effort on this!!
Biohazard
led-panzer
07-03-2011, 10:57 PM #7
Excellent document. Thank you very much OM616.
1985 300D 280,000 miles RIP
led-panzer
Syncro_G
0-60 in 29 sec
280
07-04-2011, 05:26 PM #8
That's a nice writeup. I like that it explains the controls of the pump.
Now that were seeing what not to do, it would be cool to distill a new step by step power tune procedure from it.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
300D50
07-04-2011, 05:31 PM #9
It's all in there. Wink
Start with a known working pump, document what you do, and follow the guidelines.
Tune a mans car, he's happy for a week.
Teach a man to tune his car, he's happy till he needs a larger turbo!
300D50
Syncro_G
0-60 in 29 sec
280
07-04-2011, 05:55 PM #10
(07-04-2011, 05:31 PM)300D50 It's all in there. Wink
I'll have to read it a few more times then. Smile
Edit: on further thought and reading, what i gather is that several adjustments are interdependent.
That would worry me if I were to start messing with any of the settings.
So I would think there's a specific or recommended order to adjustment.
Should I assume that that procedure is covered in the official Bosch manual and this doc is supplemental to the official manual?
It's perfectly fair if this is the case but it should probably be stated explicitly -- something like a "how to use this doc" statement. Especially since the instructions we had a while back for RL removal were sort of a f*** the manual kind of deal.
Overall I'm pretty stoked on the information there.
This post was last modified: 07-04-2011, 07:29 PM by Syncro_G.
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
OM616
10mm MW
574
07-04-2011, 08:34 PM #11
(07-04-2011, 05:55 PM)Syncro_G
Bosch does have a specific order that they want their pump guys to do the adjustments.
As for making "performance" adjustments, I have developed a sequence that I make the adjustments, but it depends on what you want to adjust. I will not share my procedure, sorry.
Before I pull the back off of a RW, I get a feel for how the engine responds to the throttle, and then I pull the cover an make an "O SHIT" change, (make several adjustments at once based on experience and evaluation), Usually I have to go in one more time to fine tune one thing or another.
Nothing in the doc relates to the MW/RW manual. Everything in there we are throwing out the window. The doc is all from my understanding and experience, not Bosch.
I have had several cars towed to me to have me straighten out what the owner did to his governor. I super highly recommend that no one remove the back cover.
OM616
randomdude
07-05-2011, 02:01 PM #12
since a lot of this revolves around the "rack" can anyone post a pic of one? ive searched a while on google and not had good luck.
i may have seen it but not known what it was since this is my first time playing with IP's. but im tryin!!! lol.
This post was last modified: 07-05-2011, 02:02 PM by randomdude.
cars? what cars? WHERE???
randomdude
ronnie
07-05-2011, 07:12 PM #13
The actual rack is hard to see without taking the ip apart. Thermo king diesels(made by izusu) Have a cover plate that you can see the rack itself. It looks like rack and pinion steering gears. What you most likely want to see is the rack limiter, and it adjustment. There is a good picture of it in one of the recent posts on this forum.
ronnie
07-06-2011, 01:34 AM #14
That is an awesome Read OM616. THANK YOU. It makes perfect sense.
One of the important things that stood out to me is that it seem thats TC and Max rpm should be, I would say, adjusted equally. Return to Idle seems easy enough to achieve
.... Now to put the rack limiter back in .... Dodgy
Oh! Speaking of that, You had mentioned briefly on possibility of a SLIGHT rack limiter adjustment being made, but I did not see anything about it later. Is it something that will be added later?
Please understand I do not mean to push you here, Just trying to ask some intelligent questions. Give me some time, I will explore myself on my virgin (Rack limiter less) pump
Don't yell at me! Blush
300D50
07-06-2011, 04:49 AM #15
In this case, "slight adjustment" means you can adjust it to let the rack travel slightly further, and it should work.
We also need some back cover and side cover shots if anyone has their IP apart.
300D50
07-06-2011, 10:28 AM #16
Give me a couple days, I will post some
08-25-2011, 03:36 PM #17
(07-06-2011, 10:28 AM)Captain America Give me a couple days, I will post some
So did anyone every repost the back of a MW pump telling what is what? i really want to turn my pump up, but dont want to mess it all up
aaa
08-25-2011, 03:45 PM #18
Somebody label this:
http://www.superturbodiesel.com/std/Thre...8#pid32698
This post was last modified: 08-25-2011, 03:45 PM by aaa.
aaa
08-25-2011, 04:09 PM #19
(08-25-2011, 03:45 PM)aaa Somebody label this:
I would, but i dont know which is which Tongue
08-25-2011, 11:33 PM #20
I think I have it correct Angel
[Image: MWPumpLabeled.png]
And Forced, Douche's pic below:
[Edited for content. Sorry]
This post was last modified: 08-26-2011, 06:54 AM by winmutt.
carlitosgy6
Ranger Turbodiesel
144
08-27-2011, 09:06 PM #21
(08-25-2011, 11:33 PM)Captain America I think I have it correct Angel
THANK YOU I REALLY NEEDED THAT INFO!!!
carlitosgy6
08-27-2011, 10:01 PM #22
(08-27-2011, 09:06 PM)carlitosgy6 THANK YOU I REALLY NEEDED THAT INFO!!!
Not a problem!
Why cant his pic be up? "permission is granted to copy and/or distribute as long as this picture is not altered"
This post was last modified: 08-27-2011, 10:07 PM by Captain America.
Not a problem!
08-30-2011, 08:16 AM #23
(08-27-2011, 10:01 PM)Captain America Why cant his pic be up? "permission is granted to copy and/or distribute as long as this picture is not altered"
Because I don't want any more headaches. Yours is going into the IP thread Big Grin
08-30-2011, 04:29 PM #24
Easy enough! lol Angel
When I finally get around to taking mine apart, I will take a pic with a clean IP and relabel
I tried to label it based on the terminology OM616 used in his pump theory document
This post was last modified: 08-30-2011, 04:33 PM by Captain America.
carlitosgy6
Ranger Turbodiesel
144
08-30-2011, 07:43 PM #25
I can take a better pic if you want
carlitosgy6
08-30-2011, 11:23 PM #26
(08-30-2011, 07:43 PM)carlitosgy6 I can take a better pic if you want
Sure! If you are able to clean the oil off (brake clean?) and focus a tad better I think it would help a lot Wink
09-01-2011, 08:30 AM #27
Can someone please tell me how they broke the locking ring loose on the torque control? Last time i unsuccesfully tried, it was i giant PIA, and i gave up and everything back together because i had to have the car the next day
09-01-2011, 01:25 PM #28
IIRC I ground a socket down to fit.
This post was last modified: 09-01-2011, 01:26 PM by winmutt.
OM616
10mm MW
574
09-01-2011, 01:44 PM #29
(09-01-2011, 01:25 PM)winmutt IIRC I ground a socket down to fit.
Take a 13/16 spark plug socket and grind the end so it has two tabs about .100" wide, 180 degrees from each other. The tabs only need to be about .125 tall.
The spark plug socket is nice because it has a hex for a wrench. This is a nice feature on the 617.
Remember that the capsule will rotate when you loosen or tighten the lock ring. You must note its position prior to loosening the lock ring, and confirm its position after tightening the lock ring.
After you have the lock ring broken loose, (1/8 to ¼ turn), make sure that when you turn the capsule, the ring stays put, other wise the lock ring will move with the capsule, and when you go to tighten the lock ring, you will just be turning the capsule back in.
OM616
09-01-2011, 04:20 PM #30
Thanks for the info OM616
Do you approve of the labeling on the pump picture?
OM616
10mm MW
574
09-01-2011, 04:46 PM #31
(09-01-2011, 04:20 PM)Captain America Thanks for the info OM616
Looks fine from where I'm sitting, Wink
OM616
carlitosgy6
Ranger Turbodiesel
144
09-01-2011, 08:27 PM #32
ill do it tomorrow
carlitosgy6
ill do it tomorrow
09-01-2011, 09:06 PM #33
thank you very much om616. I appreciate the document you typed up and all the information you provide. I dont think i would even come close to understanding a mw pump without your MW Theory Tongue[/i]
This post was last modified: 09-01-2011, 09:06 PM by MFSuper90.
09-01-2011, 11:47 PM #34
(09-01-2011, 04:46 PM)OM616
Your Blessing is much appreciated! Heart
E300TSC
Turbo-Supercharged
321
09-12-2011, 05:19 AM #35
I just went to check this out and it seems to require a Google account which I don't have... Sad
E300TSC
09-12-2011, 03:47 PM #36
Works for me without logging in
E300TSC
Turbo-Supercharged
321
09-12-2011, 04:07 PM #37
Do you have G-mail or any google related sign-in's? Maybe my youtube log in would work...
E300TSC
09-13-2011, 01:36 AM #38
I do but not logged into it when I load the page. PM me your email address
E300TSC
Turbo-Supercharged
321
09-13-2011, 06:37 AM #39
For grins, I just typed in my usual forum password and it let me in. I must have set something up with Google in the past. Got the document now, thanks to OM616 for the time and effort put into this!
E300TSC
09-13-2011, 09:50 AM #40
HELP / INFO please
Will a pump from a 300GD work on the OM 617.952 engine. Also, I was told by the seller that the "M" Pump did not have an ALDA. Is that true. Below is the pump's info. Will this work for my 1985 300D Turbo ?
Please let me know. I am getting ready to buy myself an "M" pump finally.
Thanks in advance.
Data Plate:
PES5M55C320RS105
011 649 31193
0 400 075 999
617 070 1901 EPRO4
BOSCH
HELP / INFO please
Thanks in advance.
Data Plate:
PES5M55C320RS105
011 649 31193
0 400 075 999
617 070 1901 EPRO4
BOSCH
09-13-2011, 01:11 PM #41
300GD is almost certainly going to be om617.91x and would not have an alda. I would also imagine that the GD is tuned for torque. If you are planning on upgrading(rebuild and elements) this then you are gtg, otherwise pass.
Do you need a new pump?
09-13-2011, 03:14 PM #42
Hey,
I am looking for a "M" Pump for a rebuild ... SUPER PERFORMANCE BUT also OK for everyday driver. So is this OK ? No ALDA ? So I guess I will be getting rid of some vacuum elements and lines. New Pump ? You have one for sale ? Thanks
Hey,
cjcosta
12-07-2011, 12:03 AM #43
Great doc. Thanks.
Maybe after reading it a few more times i get my hands on the IP.
cjcosta
Great doc. Thanks.
lpumb3
617 300sd
141
10-02-2012, 12:29 PM #44
awesome write up om616
, ill be re-reading it a few times . if i get most of the fine balance act of tuning it ill be happy .it seems like for every turn in or out you make you have to mirror/negative the adjustment on the other end of the spring , is the ALDA and shutoff valve the only pressure actuated fuel delivery function on these pumps? i have an auto so i have the trans functions . having trouble finding a good vacume thread on here, for tuning my tranny , before i start tinkering with pump etc ?
This post was last modified: 10-02-2012, 05:20 PM by lpumb3.
lpumb3
