STD Tuning Engine Drip timing on a 85 Cali car?
dieselboy
Rotatin 5500 times a minute
680
07-09-2011, 02:07 PM #1
Is there some specific way to do it?
I'm getting a reading of 14° retarded.
The car has smoke on the top end and has alot of intake noise.
This post was last modified: 07-09-2011, 02:28 PM by dieselboy.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
07-09-2011, 02:38 PM #2
Not unless there is something different with the emissions BS that I dont know about.
Have you tried advancing it at all?
dieselboy
680
07-09-2011, 02:42 PM #3
Nah were going to mess with it tomorrow. My car too. Mine dripped out to 11° advanced lol.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
07-09-2011, 03:19 PM #4
Oh wow. Mine was at 18 advanced and it ran like poop
Hercules
07-09-2011, 05:31 PM #5
A little different slant at timing pump,very accurate. Attach a 2ft.long hose with banjo fitting at inj.pump fuel inlet,attach second hose to #1 cyl. inj.pump outlet by using part of( extra ) steel line,insert the free end into a small clear container,place container higher than pump,where can be easily seen, fill with water. .Following pump timing procedures. Just blow through fuel inlet hose ,watch bubbles exiting outlet hose. When bubbles just stop or slow to one every (3) sec. pump timed. Nice thing about this method,Both hands are free,easy to see. Don"t worry, have used this method many times,compared to drip method ..
Hercules
dieselboy
680
07-10-2011, 11:59 AM #6
Drip method seems eaiser.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
Syncro_G
0-60 in 29 sec
280
07-10-2011, 12:54 PM #7
timing on '85 Calif car is the same as on other 617.952 engines.
If you have an '85 (and probably other years- ?), you have the port for the riv tool. they can be expensive but if you know someone nearby with one, try to borrow it.
Good luck. I still haven't figured out the drip method.
'84 G-Wagen turbodiesel
'75 240D 4-Speed
Syncro_G
'75 240D 4-Speed
dieselboy
680
07-10-2011, 02:35 PM #8
I dripped a friends Sd and it's perfect. His wagon is a 85 and its giving us a 17° retarded reading. My car is saying 11° Advanced
This post was last modified: 07-10-2011, 02:35 PM by dieselboy.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
Biohazard
Smokin like a champ!
376
07-10-2011, 03:35 PM #9
(07-09-2011, 05:31 PM)Hercules A little different slant at timing pump,very accurate. Attach a 2ft.long hose with banjo fitting at inj.pump fuel inlet,attach second hose to #1 cyl. inj.pump outlet by using part of( extra ) steel line,insert the free end into a small clear container,place container higher than pump,where can be easily seen, fill with water. .Following pump timing procedures. Just blow through fuel inlet hose ,watch bubbles exiting outlet hose. When bubbles just stop or slow to one every (3) sec. pump timed. Nice thing about this method,Both hands are free,easy to see. Don"t worry, have used this method many times,compared to drip method ..
This does seem a bit easier to me. Quick question, or clearification. I'm assuming you still pull the innner part of the delivery valve out of #1 to use this meathod? It seems you would have to, but I would like to make sure I'm on the same page. Thanks!
Biohazard
Hercules
07-10-2011, 04:53 PM #10
Yes, same method as drip. Note , can back up engine when timing,be sure to back up min. 30 deg.,This is ok"ed by Mbz. I use p/s pulley nut to rotate engine,Just push down on belt if pulley slips or tighten loose belt. Using bubble method allows single person to time pump,very easy seen,remember timing is set rotating engine to just fuel stop. Must have vac.pull disconnected,and throttle at full. (best with engine Off) lol;
Hercules
Biohazard
376
07-10-2011, 05:56 PM #11
Awesome info! Thanks again for the great tip!
Biohazard
dieselboy
680
07-11-2011, 02:19 PM #12
Would the engine even run worth a crap at 17° retard?
I'm doing it exactly like we did his Sd and the Sd runs great.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
07-11-2011, 03:15 PM #13
I wouldnt think it would run or even try to!
Like I said mine ran like shit @ 18° BTDC not ATDC haha
This post was last modified: 07-11-2011, 03:17 PM by Captain America.
Biohazard
376
07-11-2011, 03:22 PM #14
^^^ What he said. I'm going to try this method on my brothers car and see what it shows. Hopefully, Wed afternoon. I have to replace the lift pump gasket anyways, to I'll be in the right area at least! LOL
Edit: GAH! It's only Monday, not off till Wed. DAMN!!
This post was last modified: 07-11-2011, 03:43 PM by Biohazard.
Biohazard
07-18-2011, 09:17 AM #15
I've never had any luck with drip timing really. Just get the lock tool for the A/B port and time it that way.
This post was last modified: 07-18-2011, 09:17 AM by winmutt.
Biohazard
376
07-18-2011, 10:33 AM #16
Didn't have time to check timing. I'm putting rebuild injectors in his car this Wed, will try retiming it after that.
Biohazard
Biohazard
376
07-20-2011, 03:47 PM #17
Got the rebuilt injectors put in and used Hercules' method of timing the pump. WAAAY easier! I set it to 26 BTDC and it is running like a champ again. I would highly recommend this method for setting timing. Big Grin
Biohazard
led-panzer
07-21-2011, 10:02 PM #18
(07-18-2011, 09:17 AM)winmutt I've never had any luck with drip timing really. Just get the lock tool for the A/B port and time it that way.
Where might I be able to buy said tool?
1985 300D 280,000 miles RIP
led-panzer
07-22-2011, 10:12 AM #19
rusty @ buymbparts.biz is where I get all my stuff. He recently hooked up with Autohaus AZ's distrib so he can beat them on 95% of the goods.
