STD Other Open What the hell were you thinking...?
rolfi
My 300D is Onion-yellow!
79
08-19-2011, 04:14 AM #1
I have asked this question numerous times, after starting the work on my W123... Yesterday the same question came up in my mind, when my accelerator linkage broke... The rubber bushing/spacer that originally seems to be GLUED on, came loose..................
It would be fun to have a thread to sum up flaws and weird solutions which originally were done on our cars... And if someone has a good solution to the flaws (the flaws which can be fixed, of course), they can post it up. After everything is summed up and everyone has improved everything, we will have perfect cars Big Grin
Post up whatever you want. I'll start off with one:
(W123 300D Turbo)
...When GLUEING on a rubber bushing on the accelerator linkage, which sits ON the engine and is exposed to heat, oil and diesel as well as being put under load whenever I push on the pedal?
This post was last modified: 08-19-2011, 04:16 AM by rolfi.
-rolfi
1980 Mercedes-Benz 300D (US-spec)
+BMW E12, E21, E28, E30 and E32
rolfi
(W123 300D Turbo)
-rolfi
dieselboy
Rotatin 5500 times a minute
680
08-19-2011, 11:42 AM #2
I've always been confused as to why mercedes did such odd linkage for the throttle. That and swaybar on the firewall.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
08-19-2011, 12:28 PM #3
I think the throttle linkage has some thing to do with safety in an accident???
As far as the sway bar in the fire wall I have no frigging idea what a PITA
This post was last modified: 08-19-2011, 12:29 PM by willbhere4u.
smoke026
When the Cat's away the mice will play!
94
08-19-2011, 06:55 PM #4
Have not owned my long enough to discover its bugs, but I do have a concern on why all W123 instrument clusters were so poorly designed as far as lighting is concerned. I have now corrected mine by placing aluminum foil in the Bulb Tunnel. But I still think they suck, I mean 80's already had nicely lid clusters. I had a 62 Bug that had WAY better lighting on the cluster.
smoke026
smoke026
94
08-19-2011, 09:03 PM #5
Another one:
On OM617
Not sure why there wasn't a type of gasket to seal the top of the oil separator inside the air filter from the factory instead of those funny metal spades.This causes oil misting/sippage inside your air cleaner.
What's up with the crappy oil filter? Maybe back in the day the cotton waste was purer?
This post was last modified: 08-19-2011, 09:10 PM by smoke026.
smoke026
Another one:
On OM617
Oil Burner
Turbo Everyting!!!
83
08-19-2011, 11:44 PM #6
What Dumb A** decided it would be smart to put the air cleaner above the hotest thing in the engine compartment come on even then they new cool air was better than hot air!
and what moron thought the locks should be on the same circuit as the engine shut down circuit
These are my bigest ...What the hell were you thinkings
Oil Burner
98taco3
08-20-2011, 02:26 AM #7
Using a vacuum system to run literally every damn thing in the car. Miles of multi colored spaghetti running every which way. something as small as the Gas door lock actuator goes bad and all sorts of problems can surface. stuff like the car wont shut off, locks wont lock/open. Actuators for the climate control fail and are buried in the dash board. There were electric locks in the 60s, why couldn't Mercedes have put em in these cars?
Also the window regulators made out of pot metal and not supported adequately. Never seen a car eat window regulators like these can!
98taco3
08-20-2011, 08:02 AM #8
I always think wtf can't you put thw fuel tank somewhere that allows the rear seats to fold down. Wouldn't that be nice, a trunk to rear seat opening. Another one that screwed me recently, that formed heater hose that passes right over the oil filter. Owners have bent that thing back and forth fighting the filter out and sure enough it blew up on me.
Re om617 w123
Re om617 w123
smoke026
94
08-20-2011, 07:53 PM #9
(08-20-2011, 02:26 AM)98taco3 Using a vacuum system to run literally every damn thing in the car.
I have to disagree with this one..I think that this was a great idea.8)
I'll take a fully mechanical vacuum system any day over 100 relays,chips,computers,fuses etc...
Best of all, fully mechanical Diesels are EMP proof!!!
smoke026
Hercules
08-21-2011, 01:07 AM #10
What the ---- were you thinking installing a single row timing chain (380 engines ) By 50,000 mi would jump bend valves.
Sad part,used single row chain in earlier six cyl.Did not work, changed to double row on all engines .
Did Mbz forget????
Hercules
Did Mbz forget????
Oil Burner
Turbo Everyting!!!
83
08-21-2011, 04:33 PM #11
What the he'll were you thinking only selling automatic 300's in the US and why with all the options we are not pompous a**es here in the states!
We are more redneck...hell we invented the redneck
Oil Burner
08-21-2011, 08:32 PM #12
(08-21-2011, 04:33 PM)Oil Burner What the he'll were you thinking only selling automatic 300's in the US and why with all the options we are not pompous a**es here in the states!
+1,000,000!
+1,000,000!
mike-81-240d
more like mike-84-300d now
427
08-22-2011, 10:05 PM #13
I have to agree on the fuel tank one.
What the hell were they thinking when they gave the car 4 speakers, When it costs the equivalent of 50 grand it should have at least 2 more.
This post was last modified: 08-22-2011, 10:05 PM by mike-81-240d.
mike-81-240d
dieselboy
680
08-22-2011, 11:18 PM #14
If I believed in god I'd sure as hell want to know what the fuck he was thinking when he created the woman's mind.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
08-22-2011, 11:42 PM #15
I believe and yes I wonder haha
rolfi
79
08-23-2011, 12:49 AM #16
I found a solution to the accelerator linkage problem. Three M6x40 bolts, three M6 lock nuts and a 6mm drill. Had to cut them a little, as 40mm long bolts were somewhat too long... Anyway, it works fine as hell now Smile I'll post a pic later.
-rolfi
rolfi
-rolfi
DanielK
Big Plans, No Clue
98
08-23-2011, 04:23 PM #17
What the hell was Hans thinking when he decided that the larger body cars didn't need 90 degree hood hinges? This goes for the SL's and the SD's for sure. not sure on others.
What was Lars thinking when he thought it was a wonderful idea to put the lower ball joint on the inside of a cup on the front knuckles? Doesn't he know that is impossible to get to?
What was Dietrich thinking when he made up parts that required specialized tools? These cars are littered with them.
[Image: FalkonSig.png]
DanielK
08-23-2011, 05:58 PM #18
(08-23-2011, 04:23 PM)DanielK What was Dietrich thinking when he made up parts that required specialized tools? These cars are littered with them.
Job security for mbz techs
08-24-2011, 08:46 AM #19
1. The frequently mentioned fuse box cover on 123s. Just a PITA even if you do it just right.
2. The nearly inaccessible motor mount hardware consisting of easily rounded out cap screws in a deep hole.
3. The damn near impossible to easily remove oil cooler lines, should have been a replaceable short flexible section in the place where they all leak, just like the trans cooler lines, but for some reason, its one unit all the way.
4. The circular jack mount hole on a lot of models, and rounded bottom jack. Why make the jack so inherently unstable? and why design into the car a major rust point that will almost certainly start rusting if you ever use the jack and damage the finish? Should have been a hardpoint like hondas, or something else exterior, nothing that actually goes into the rocker panel. That was a big mistake rust wise.
This post was last modified: 08-24-2011, 08:46 AM by JB3.
Oil Burner
Turbo Everyting!!!
83
08-24-2011, 10:42 AM #20
What's a PITA u guys like your acronyms
Oil Burner
08-24-2011, 11:13 AM #21
(08-24-2011, 10:42 AM)Oil Burner What's a PITA u guys like your acronyms
PITA= Pain in the Ass
Also, AFAIK= as far as I know.
For the longest time I though AFAIK was some kind of brand Big Grin
rolfi
79
08-24-2011, 11:40 AM #22
[Image: IMG_20110821_161716.jpg]
[Image: IMG_20110821_161724.jpg]
THERE! I FIXED IT Big Grin
-rolfi
rolfi
-rolfi
08-24-2011, 03:11 PM #23
^^^ Nice fix Rolfi!
I am determined to get rid of all that sloppy linkage shit when mine goes back together!
^^^ Nice fix Rolfi!
rolfi
79
08-25-2011, 02:36 AM #24
(08-24-2011, 08:46 AM)dropnosky 3. The damn near impossible to easily remove oil cooler lines, should have been a replaceable short flexible section in the place where they all leak, just like the trans cooler lines, but for some reason, its one unit all the way.
If you cut the outer steel part which is pressed on the hose, you can replace the hose only and just use hose clamps to keep it on. That way you keep the threaded nut and the flanged part original.
I did this on my leaky trans cooler line Smile
-rolfi
rolfi
-rolfi
08-25-2011, 06:50 PM #25
(08-19-2011, 06:55 PM)smoke026 Have not owned my long enough to discover its bugs, but I do have a concern on why all W123 instrument clusters were so poorly designed as far as lighting is concerned.
Brand new with prisms and bulbs they are not dim at all..
08-25-2011, 06:52 PM #26
(08-19-2011, 11:42 AM)dieselboy That and swaybar on the firewall.
99% sure MB invented the sway bar, so lets be thankful they did!
08-25-2011, 10:21 PM #27
(08-25-2011, 06:52 PM)winmutt
lol they dont drive like they do
