STD Maintenance General 240D stalls out when driving on highway
Purplecomputer
Slowness 220D
897
10-03-2011, 01:53 PM #1
Hey guys, My 240D seems as if its going to stall out on the highway when im driving on regular diesel fuel. I do drive this car on WVO and i do not have this problem when switched over. I think it may be a clogged filter but im not sure. Also the car makes a grinding noise when i hit bumps and the car goes up and down as wel as a less noticable grinding noise when im driving on flat surface.
any ideas cause im stumped!
Purplecomputer
vstef_is
10-03-2011, 03:24 PM #2
Check the pre-filter (small transparent thingy) and fuel filter. I'd wager a beer that's the problem. Also check the granularity on the fuel filter, and go a notch up. Not sure about the diesel in your area.
And while you're at it, have a quick look at the air filter....
As for the grinding noise... hmmm... shock absorber? Not sure...
vstef_is
Purplecomputer
Slowness 220D
897
10-03-2011, 06:12 PM #3
thats pretty much what i figured it was, Ill post back when im able to change it. The diesel in my area is pretty good. How would i go about testing it? that is the first i have heard you could test fuel.
The girding noise is pretty annoying. Its not a loud noise but you can hear it enough to drive you crazy. I feel like its coming only from the driver side.
Purplecomputer
vstef_is
10-04-2011, 12:32 AM #4
Well I wouldnt so much as say "test diesel" but you get a feel for it.
Meaning, how much water there is, how clean it is, how "rich" it is... For example in Romania depending on the station, you can get watery diesel, or just plain diesel.
Go anywhere in Europe and you get a lot better diesel, the car's faster, more powerful, runs cleaner and eats up less fuel.
Try switching stations and see if there's any difference. It may not be a problem for you, but tryin around different stations doesnt hurt anyone.
vstef_is
w123love
Stockish
354
10-04-2011, 12:48 AM #5
I’d agree and do a once over on all of the filters. Best to eliminate the easy stuff before going more in depth. If you find serious clogging in the fuel tank strainer then you may have some more serious issues. But it’s not the end of the world.
The VEGEWGN
w123love
The VEGEWGN
Purplecomputer
Slowness 220D
897
10-04-2011, 06:24 PM #6
thanks for the help guys. I actually stalled out completely today after the engine shook violently while in third gear. My dad came to pick me up and he took it for a drive all the way home and confirmed it was a fuel problem. Im going to clean out the tank and all the lines tomorrow morning.
Purplecomputer
10-04-2011, 08:10 PM #7
tank strainer?
swap supply and return fuel lines?
Classic tricks to sucking fuel through gummy lines
tank strainer?
Purplecomputer
Slowness 220D
897
10-05-2011, 09:23 AM #8
So i woke up super early with the intent to remove the tank and clean it, So i started by removing the tank's pre filter and to my surprise it was new and completely clean.
[Image: th_IMG_20111005_073943.jpg]
so i moved forward, all the lines conected to the tank were new and did not needed to be reaplced. It kinda looks dirty from the pciture but compared to some others ive seen this did not have any gunk build up on the filter at all
In the engine compartment this is what i found!
[Image: th_IMG_20111005_073953.jpg]
It had all this brown gunk in there and this clumped up gunk. Probably from the wvo that was mixed in when i first started to convert the car and was very unsuccessful
I also bought some diesel Kleen and added about 4 ounces to the car in hopes the injector knocking will cease and clean the lines.
This post was last modified: 10-05-2011, 10:21 AM by Purplecomputer.
Purplecomputer
