Runs rough after reinstalling IP
More problems, ohyes.
The IP was removed from the engine for turning up fuel delivery. When the mechanic reinstalled it, the car ran rough as hell when hot. As soon as it got cold, it wouldn't start. I was helping him out today, pulling it once again and reinstalling it on (what I believe is) the correct stroke.
Well, it starts.. And it runs, with less knocking than it have ever had.
The problem is that it still runs kind of rough. Any ideas?
24 BTDC and the marks on the IP set correctly. The system was bled while it was running, so that shouldn't be the problem either.
http://www.youtube.com/watch?v=Qk9XcHwQIAE
I'm sorry if this is a stupid question, but both me and the mechanic has very little experience with diesels.
Reach out to Mr. Diesel Meiken !
Might ck. injector spray pattern, debris can inter any time lines are off,and metal can chip off inside line if any bending was done. Not to get stuck on just pump thinking,rule out all poss. things,Motor mounts,valve adj.etc.( Kinda rough) means checking all things that have not be inspected for a while. Good luck.
(10-26-2011, 01:38 PM)Hercules Might ck. injector spray pattern, debris can inter any time lines are off,and metal can chip off inside line if any bending was done. Not to get stuck on just pump thinking,rule out all poss. things,Motor mounts,valve adj.etc.( Kinda rough) means checking all things that have not be inspected for a while. Good luck.
Thank you lots!
One injector was really bad, and another was somewhat bad. Replaced both, and now it runs smooooth
And now it leaks oil... Quite alot, actually. Have to check it out later today...
I'm not too excited about the though of maybe having to rebuild that antique tractor engine...
