STD Tuning Engine engine oil
engine oil
engine oil
11-02-2011, 06:08 AM #1
what engine oil you use?
im not a friend of thin hitech oil on old mercedes i used a 15w40 for the 603
what should i go for the 606?
thx
This post was last modified: 11-02-2011, 07:06 AM by hansebanger77.
hansebanger77
thx
11-02-2011, 01:31 PM #2
mobile1 15w40 in my 617 and every other vehicle we own including perkins, cummins, cats, valmets, etc...
11-02-2011, 02:42 PM #3
thank
i use the 15w40 also in my MF ,CASE. ect.
but im not sure by the 606.
hansebanger77
thank
11-02-2011, 04:40 PM #4
Last time I used some high mileage pennzoil 10w40 in my 617, it seems to work pretty well. I usually add some seafoam a day or two before changing and it seems to run a little better each time.
dieselboy
Rotatin 5500 times a minute
680
11-03-2011, 01:24 AM #5
Delo 15-40w le.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
Delo 15-40w le.
-Jesse
70 f250 390
66 Volvo amazon
vstef_is
11-03-2011, 04:28 AM #6
I've used 15w40 as well in the 617, and I've also tried 20w50 which runs fine (a tad bit higher oil pressure at idle on a warm engine) but winds slower on a cold start. I'll switch back to 15w40.
vstef_is
11-03-2011, 04:52 AM #7
Your 606 in your area should be using 0w 40 or 5w 40 synthetic MB 229.3 or 229.5 spec oil.
Here is a MB approved list of 229.3 or 229.5 spec oils.
http://bevo.mercedes-benz.com/bevolisten/229.5_en.html
11-03-2011, 11:54 AM #8
(11-02-2011, 02:42 PM)hansebanger77 thank
Not to jack your thread or anything,
but out of curiousity what massey do you have?
11-03-2011, 01:47 PM #9
A little 165 with a little turbo from Mercedes sprinter hehe:-) i make a post in non mbz Forum later
hansebanger77
11-03-2011, 09:39 PM #10
(11-03-2011, 01:47 PM)hansebanger77 A little 165 with a little turbo from Mercedes sprinter hehe:-) i make a post in non mbz Forum later
Sounds like a runner. ill be waiting on that thread Tongue
jonbobshinigin
11-04-2011, 12:25 AM #11
Mobil 1 5W40 Turbo Diesel Truck Synthetic has been run for 10k miles on a 603 and came back with good oil analysis results. Around 8-10k I began planning my oil change. I've been running this oil on my 603 since 160,000 and I'm around 195,000 now.
1987 300TDT - 260,000 Miles
jonbobshinigin
11-04-2011, 05:26 AM #12
Used to use 15w-40, but for the last couple years have been using 5w-40 on my 617 or 616. Huge difference in cold weather cold starts
Volker407
naturally aspirated
157
11-05-2011, 04:37 AM #13
for the OM606 I would use fully synthetic 5W-40 and change every 10.000-15.000km
Gruß
Volker
Volker407
Gruß
Volker
