STD Tuning Brakes hydroboost?
hydroboost?
hydroboost?
11-07-2011, 05:54 PM #1
Looking at what its going to take to get my OM617 into my 115, and id like to keep that stock oil filter which the vacuum boost canister hits.
Searching around online, I find a lot of aftermarket hydroboost setups available. What do people think about adapting one of these setups to an MB? Sure would be convenient if I had a wagon engine to put in, then conceivably I could use the SLS pump setup to run the hydroboost brakes
This post was last modified: 11-07-2011, 05:56 PM by JB3.
iheartboost
11-07-2011, 06:57 PM #2
whats hydroboost? all i could find is its power steering ?
00 Mustang gt drift car
iheartboost
11-07-2011, 08:08 PM #3
Yeah, what is hydroboost?
Maybe you can keep the same arrangement, but use a narrower booster. Like a 7 inch dual diaphragm typically found on Street Rods.
http://www.speedwaymotors.com/Garage-Sal...55991.html
http://www.ebay.com/itm/7-inch-Dual-Brak...2225wt_754
Or move the master cylinder.
Some example pictures.
Under the floor with Brake pedal.
Under the floor with booster and brake and clutch pedal.
And other mounting styles of the master cylinder.
waz
11-07-2011, 09:11 PM #4
I don't know if this will help or not but, I've got a hydro-boost system on my '04 Chevy Avalanche from the factory. I like it. I don't know why they put it on my gasser but, it's there.
I've also seen the system on a 2002 6.0L (Gas) Silverado 1500HD, and 6.6L Duramax pickups.
The hydro-boost system from GM uses the power steering pump to provide hydraulic brake assistance.
waz
11-07-2011, 09:41 PM #5
(11-07-2011, 09:11 PM)waz ...
Oh yeah I've seen those on old Caddies and some trucks.
11-08-2011, 02:57 AM #6
My dads '90 Chev Dually has hydro boost. They general put it on larger work trucks just because it provides MUCH more braking power and will provide more braking assist after the engine is shut off. Also much more compact in size.
[Image: 172799d1238269038-hydroboost-conversion-...iagram.gif]
[Image: Hydroboost.JPG]
11-08-2011, 04:10 PM #7
Old e23 BMW's 733I,735I had hydro boost back in the early 80sBig Grin
This post was last modified: 11-08-2011, 04:13 PM by willbhere4u.
yankneck696
395
11-24-2011, 06:43 AM #8
Some of the S-19s had a real small vac booster. Should bolt right in place of yours. Hotrodders used them & A-10s w/ 350s. Sold alot of them while in auto salvage.
Ed
yankneck696
Ed
kmaser
Turbocharged G-Wagen
125
12-18-2011, 02:21 PM #9
I have hydroboost on my g wagen with an OM617a, HUGE improvement in braking performance and free'd up some space.
kmaser
12-20-2011, 08:30 AM #10
(12-18-2011, 02:21 PM)kmaser I have hydroboost on my g wagen with an OM617a, HUGE improvement in braking performance and free'd up some space.
awesome! was it stock to the G-wagon? or did you move it in from something else?
kmaser
125
12-25-2011, 10:46 AM #11
I removed the factory vacuum booster and installed a universal kit from Hydratech, the difference is amazing and the kit was super easy to install!
kmaser
12-26-2011, 10:51 AM #12
(12-25-2011, 10:46 AM)kmaser I removed the factory vacuum booster and installed a universal kit from Hydratech, the difference is amazing and the kit was super easy to install!
it looks like a nice product. Did you adapt the MB master cylinder, or did you go with the optional included vette master? Seems to be a pretty decent solution actually.
how did it come on the back side, any issues attaching it to the brake pedal?
also, any pics!? Big Grin
kmaser
125
12-29-2011, 08:54 PM #13
I measured the bore on the MB master cylinder and used a GM cylinder with the same bore and similar setup. On the backside it came with a yoke that hooked right up, only things I had to do was re-drill the adapter plate to match my firewall and made adapter brake lines with metric on one end and standard on the other. They supplied the correct flare nuts, I bent new lines, flared, installed and bled the brakes and steering system. The lines on the MB pump are standard hydraulic fitting but on the steering box it was not so I had to cut the end off and weld on a JIC fitting which was $20.00 at the local hydraulic shop.
kmaser
Freefuel
07-01-2012, 09:18 AM #14
Very cool! here is a link to a guy that does this for Jeeps and such. http://www.vancopbs.com/category_s/66.htm
(12-29-2011, 08:54 PM)kmaser I measured the bore on the MB master cylinder and used a GM cylinder with the same bore and similar setup. On the backside it came with a yoke that hooked right up, only things I had to do was re-drill the adapter plate to match my firewall and made adapter brake lines with metric on one end and standard on the other. They supplied the correct flare nuts, I bent new lines, flared, installed and bled the brakes and steering system. The lines on the MB pump are standard hydraulic fitting but on the steering box it was not so I had to cut the end off and weld on a JIC fitting which was $20.00 at the local hydraulic shop.
Freefuel
01-17-2013, 11:38 AM #15
If I understand Captain America's photo correctly, the hydroboost assist is essentially T-ed into the line going to the power steering gearbox? I'm thinking about doing this after my trans swap so I csn eliminate all vacuum crap completely
01-19-2013, 04:24 PM #16
The ones I've seen have a high pressure line from the pump to the booster, then from the booster to the steering gear.
'99-04 mustangs have hydroboost.
lpumb3
617 300sd
141
02-16-2013, 10:34 AM #17
very cool , i plan to do this as well, but a quick qauestion
i lost you at the lines on the mb pump ? th power steering pump ? did the kit come with a t fitting to pull high pressure to the booster ?
and you mentioned welding to the box , im assuming the return line fitting ?
lpumb3
Edian727
Dreams of 8mm 617
127
08-28-2014, 12:47 AM #18
I put a hydroboost on my 85 ford with a diesel. much better. It runs from PS pump to brakes, then brakes have a return and a hiogh pressure out you run to your steering box. have to have 2 return in power steering box. i drilled another return in the stock ford pump and it died so i mounted a chevy pump that had hydroboost factory.
Edian727
swampmonkey
hx40 super
280
08-29-2014, 06:53 AM #19
the v12 adaption in the w123 made me remove the vacumm brakebooster to be able to fit the "downpipe"
how big is these hydrobosters, and how much of a cost is it?
this might be a realy good solution for me!
daily driver
w115 240d 72hp 3.07 rearend
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
08-29-2014, 08:13 AM #20
They're very thin-look at kmaser's picture. Common on extra large American pickup trucks. Maybe Volvo has a similar part?
Another solution is to remove the booster completely, and use a larger bore master cylinder. Manual brakes were once fairly commong (think 80's pickups and cheap cars). It's all about building up pressure in the lines, you can assist by vacuum, hydraulics, or by displacing a larger amount of fluid.
For what it's worth, I plan to run a large master cylinder with no assist in my little Jeep project. I'll probably use a pickup truck master cylinder.
swampmonkey
hx40 super
280
08-29-2014, 08:33 AM #21
(08-29-2014, 08:13 AM)Simpler=Better They're very thin-look at kmaser's picture. Common on extra large American pickup trucks. Maybe Volvo has a similar part?
yeah, but with a turbocharged v12 im not to fond of not having sufficient brakepower Tongue
hydroboost will probably be the way, could one run that with an electric pump?
maybe change out the AC-compressor for another PS-pump to run the hydrboost on?
daily driver
+ a few more.
mbturbo.com
swampmonkey
daily driver
+ a few more.
mbturbo.com
