STD Tuning Engine Bought a GT22V...
Bought a GT22V...
Bought a GT22V...
300SD81
11-10-2008, 02:03 PM #1
Finally getting into the turbo project I've had planned for like 2 years...
[Image: fe8c_3.JPG]
[Image: 00c8_3.JPG]
[Image: 01ed_3.JPG]
[Image: 02e8_3.JPG]
[Image: 03d2_3.JPG]
[Image: ffb2_3.JPG]
I think its the same one Forced is using? I'm going to go with full electronic control though. I already have the circuit boards for a new boost and EGT gauge planned out and will be starting on the turbo computer board as soon as it arrives.. Going to implement a CAN (controller area network) just like new cars use to connect everything together. I have a friend taking engineering here at UGA and he said they have a CNC, so I might be able to get parts made on the cheap as practice for students...
Ich liebe meine Autos!
300SD81
[Image: fe8c_3.JPG]
[Image: 00c8_3.JPG]
[Image: 01ed_3.JPG]
[Image: 02e8_3.JPG]
[Image: 03d2_3.JPG]
[Image: ffb2_3.JPG]
11-10-2008, 02:28 PM #2
Basically the same. That compressor wheel looks pretty chewed up and the turbine looks like the engine was burning coolant.
$75 isn't too bad but they do say it needs rebuilding.
<!-- m --><a class="postlink" href="http://cgi.ebay.com/ebaymotors/MERCEDES-GARRETT-TURBO-AL0030-GT22V_W0QQitemZ390006335328QQihZ026QQcategoryZ33742QQssPageNameZWDVWQQrdZ1QQcmdZViewItem">http://cgi.ebay.com/ebaymotors/MERCEDES ... dZViewItem</a><!-- m -->
300SD81
11-10-2008, 02:35 PM #3
I was afraid someone would say that... I thought it was just dirt on the compressor wheel in the pic, didn't look that closely since the auction was ending in a few hours and I had to go to class...
300SD81
11-10-2008, 02:39 PM #4
Thats why I never consider buying a turbo unless they have a good picture of the compressor wheel.
It will still work and balancing should be part of the rebuild, but with worn leading edges it will lose some efficiency.
300SD81
11-10-2008, 02:58 PM #5
Would the reduced efficiency be below that of the stock turbo?
300SD81
11-10-2008, 03:02 PM #6
I don't know.
I don't know.
bgkast
VGT-Intercooled
325
11-11-2008, 11:27 AM #7
It doesn't look too bad to me.
bgkast
Telecommbrkr
Soon to be mod'ing......
97
11-11-2008, 08:32 PM #8
What is the make/model of the VNT found on the '03 & up Powerstrokes?
Mods are in the works...
Telecommbrkr
11-12-2008, 03:53 AM #9
Garrett GT3788V.
Garrett GT3788V.
300SD81
11-13-2008, 03:43 PM #10
It came in today!!
Its a lot smaller than I expected, is everyones VNT smaller than the stock turbo?
How do I figure out the exact model number of the turbo, as in GT22xxV?
300SD81
It came in today!!
300SD81
11-13-2008, 11:10 PM #11
Found out from EPC that it came from an OM647, and got a part number for the gasket. Not having any luck finding the part numbers for the oil fittings though, hopefully its a standard thread and I can probably have the return flange made. Theres no way to clamp tubing to the outside of the compressor outlet, so I'm going to have to find a way to either friction fit it inside or I'm going to have to drill into the turbo to attach it. I emailed my friend's engineering professor about using the school's CNC machine, so hopefully he'll get back to me soon.
300SD81
11-14-2008, 05:23 AM #12
You need one of these: <!-- m --><a class="postlink" href="http://cgi.ebay.com/ebaymotors/Billet-Oil-Drain-Flange-GT-Series-Ball-Bearing-Turbos_W0QQitemZ360105089753">http://cgi.ebay.com/ebaymotors/Billet-O ... 0105089753</a><!-- m -->
<!-- m --><a class="postlink" href="http://cgi.ebay.com/ebaymotors/Turbo-Oil-Drain-Pipe-Kit-Garrett-GT20-GT22-GT25-GT28_W0QQitemZ380074971453">http://cgi.ebay.com/ebaymotors/Turbo-Oi ... 0074971453</a><!-- m -->
[attachment=1]<!-- ia1 -->LMN GT2256V oil drain.jpg<!-- ia1 -->[/attachment]
The feed line is a standard metric banjo fitting, any good hydraulic shop will have one in stock.
Quote:Theres no way to clamp tubing to the outside of the compressor outlet, so I'm going to have to find a way to either friction fit it inside or I'm going to have to drill into the turbo to attach it.
I used a grinder and cut mine down to accept a 2.5" boot.
[attachment=0]<!-- ia0 -->cut.jpg<!-- ia0 -->[/attachment]
Quote:Its a lot smaller than I expected, is everyones VNT smaller than the stock turbo?
Yes. Thanks to advances in production and wheel efficiency, they don't need to be as big as the paddle wheel T3.
300SD81
11-14-2008, 10:26 AM #13
Bit tougher than just grinding it down on this one, the actuator mount is attached to the outlet. I got the actuator off and opened it up today, not sure if I can reverse engineer the signals used by the existing controller, but I can definitely build m own controller... Taking it to my house this afternoon so I can clean it without worrying about getting fined for making a mess in the bathrooms here..do I need to worry about getting water into the insides of the turbo? I'll start on the actuator circuit when I get back from the Auburn game on sunday, love to have this running in time for the drive to the bowl game, but I doubt thats going to happen.. Not sure if I want to put the entire turbo computer on the turbo or just send position signals to it yet...
300SD81
11-14-2008, 11:28 AM #14
The housing is normal aluminum. You could find the stock fitting to bolt-on or you could have one welded on.
[attachment=1]<!-- ia1 -->GT2256V compressor outlet 1.jpg<!-- ia1 -->[/attachment]
[attachment=0]<!-- ia0 -->GT2260V-5.jpg<!-- ia0 -->[/attachment]
