STD Tuning Drivetrain Place box on a 617a 722,300
chakiko
11-12-2011, 11:01 AM #1
Hi all.
I want to ride my 300tdt an automatic gearbox from a W126 280se. Is it possible this show?
¿I can have a problem?
The 300tdt mounts a 722,315,
the 280 a 722,300
Thanks and sorry for my English
chakiko
Hi all.
the 280 a 722,300
aaa
11-12-2011, 10:03 PM #2
Electric speedo, different shift points. Very possible if you get around or ignore those issues.
aaa
chakiko
11-13-2011, 02:17 AM #3
Ok. the speedo is a good reason not to
that means different shift points? It is the rpm at which gear changes occur?
You can not adjust?
chakiko
You can not adjust?
aaa
11-13-2011, 06:38 AM #4
Yeah, the rpm. You can easily adjust the light duty shift points, but for the maximum shift points you'd have to switch the entire valvebody over.
aaa
chakiko
11-13-2011, 10:01 AM #5
It is a problem.
I have 2 box 5-speed manual and 4 speed box 3.
But it is difficult to get an automatic 722,315 in Spain
chakiko
It is a problem.
chakiko
11-20-2011, 12:19 PM #6
Well, I got a box from a 300sd 722,303, but I still have the problem of the odometer.
Could we put the box back of a battered 722,315?
How about a 722,359?
chakiko
aaa
11-20-2011, 02:44 PM #7
I've switched the speedo part of these before.
aaa
chakiko
11-23-2011, 05:20 AM #8
I found a damaged 722,315 for 200 €, and € 722,357 for 100. But I'm not sure that I was worth 722,357. It is one of 91 300CE
chakiko
