STD Tuning Engine Dieselmeken shows how to fix leaking pump
dieselmeken
11-14-2011, 10:37 AM #1
This is a small clip showing how you can do to fix leaking deliveryvalveholders while the pump is still in the car.
Take care if you planning to do this operation
http://www.youtube.com/watch?v=-SW1dRGpHPU
Put a comment if you like / dislike it / Göran
dieselmeken
11-14-2011, 09:38 PM #2
I just did that on my 300sdl but I did it one cylinder/delivery valve at a time
oel_brenner
11-15-2011, 10:14 AM #3
Dieselmeken,
thanks for the great videos!
would love to see a MB "M" pump complete disassemble reassemble
video explaining along the way.
for too many people the inside of injection pumps is a complete mystery.
I for one really appreciate your contribution to the community
keep up the good work!
cars
1991 W126 350SDL turbodiesel
1987 W124 E300D turbodiesel
1987 W126 300SDL turbodiesel
1984 W107 SL300D turbodiesel
1974 W115 /8 300D diesel
trucks
boats
oel_brenner
Dieselmeken,
cars
trucks
boats
George3soccer
11-15-2011, 11:59 AM #4
Thank you goran. I don't know how you do it working and operating a camera
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
cho
01-06-2012, 05:00 AM #5
Thanks Goran, ... is this procedure same for MW55/320RS16 pump (300sd).
regards
cho
regards
dieselmeken
01-06-2012, 06:23 AM #6
No mw serie is not like this.
dieselmeken
cho
01-06-2012, 06:53 AM #7
(01-06-2012, 06:23 AM)dieselmeken No mw serie is not like this.
thanks again, I need to change a d-valve also (because my car shakes a lot after complete rebuilt),not only
copper washers,..so I have to let bosch guys do it..?
cheers
This post was last modified: 01-06-2012, 06:59 AM by cho.
cho
cheers
tomnik
01-07-2012, 12:15 PM #8
before going into the ip first check the injectors.
Compression is o.k.?
Valve job done?
Depending on what you define "shaking" you might want to search for damper screw (on the back cover of the ip).
Where from Europe are you?
Tom
(01-06-2012, 06:53 AM)cho
cheers
tomnik
Valve job done?
Tom
cheers
cho
01-08-2012, 12:51 PM #9
(01-07-2012, 12:15 PM)tomnik before going into the ip first check the injectors.
Valve job done?
Tom
hi tomnik,
engine has been rebuilt 15 days ago
compr/valve is ok, 5 injectors pop at 125-127 bar,...
yes,I have ordered rack dumper still waiting to come...
(is it possible to change it without taking oil filt.housing off?)
but few days before rebuilt I have taken pump to some bosch guys
and they told me that my elements are worn a bit, and in some
near future I have to change them ... do you or Goran have any
experience with DTP MW elements (made in Germany??) over here I can
get them 40e a piece ???
and my d-valves also had to be changed ....
btw I'm from Serbia ...
regrads
ChO
This post was last modified: 01-08-2012, 01:05 PM by cho.
cho
Valve job done?
Tom
hi tomnik,
regrads
ChO
tomnik
01-08-2012, 02:37 PM #10
Hi,
rack damper can be changed with all in place.
Are you sure you can get the small MW elements 1 418 414 001 from DTP?
Your Bosch guy, can you trust him?
There must be much to wear a diesel pump element (if fuel filter was in use and not too much red diesel was used).
Are you sure that he can not adjust the balance of the elements?
Take the pump back and install it. Then you turn the flange of cylinder 5 until idle is better.
Wait until larger MW elements are available (6 months).
Tom
(01-08-2012, 12:51 PM)cho
Valve job done?
Tom
hi tomnik,
regrads
ChO
tomnik
Hi,
Tom
Valve job done?
Tom
hi tomnik,
regrads
ChO
dieselmeken
01-08-2012, 03:33 PM #11
Its not so that you have missed the overflowvalve so that you dont have any pressure in the pump? seems quite odd that the pump would bee worse after a test & adjust in the Boschshop.
Have you timed the pump correct? Dont turn the barrel if you are not sure that you have the fault there.
Do you have a turboengine and need aalot of power? If not you dont need any bigger elements, you just need a proper adjustment.
Is the engine ok timed in crankshaft / camshaft?
/Göran
dieselmeken
/Göran
cho
01-09-2012, 03:58 AM #12
(01-08-2012, 02:37 PM)tomnik Hi,
Tom
as for bosch guys I can not be sure, because I have no knowledge at all
considering IP technologies... I will try to take a pump to another shop just to cross reference data ....
how large those elements are gonna be? I would like to stick with
default turbo ... and maybe some 6,5mm el's Smile ?
(01-08-2012, 03:33 PM)dieselmeken Its not so that you have missed the overflowvalve so that you dont have any pressure in the pump? seems quite odd that the pump would bee worse after a test & adjust in the Boschshop.
/Göran
at first while they rebuilt it IP timing degree was 15 ATDC and I told them
to correct it to default 24 BTDC. They adjusted it, but the shakes and
noise stayed.
yes,my engine is turbo but I do not need some serious additional
power (maybe if I see that I must change elements then I can try with some power increase... but I m satisfied as it is now, in basics I would like to have this engine as long as possible...)
proper adjustment over here does seem to be a science fiction because I can not find bosch guys with REAL knowledge.
as for pump timing I can only suppose what they did ... no way I can
prove anything as I have no basic knowledge about it...
video taken few days ago:
shaking OM617
no smoke morning cold start video:
no smoke
thanks guys
(01-08-2012, 02:37 PM)tomnik Are you sure you can get the small MW elements 1 418 414 001 from DTP?
nope, as I can see they offered only 1 418 415 xxx elements for MW pumps ..... Huh
This post was last modified: 01-09-2012, 04:11 AM by cho.
cho
Tom
/Göran
noise stayed.
shaking OM617
no smoke
thanks guys
dieselmeken
01-09-2012, 04:53 AM #13
To mee it sounds like a balance problem. It runs on all 5 cylinders what I can hear. Maybee Tom has another opinion.
dieselmeken
cho
01-09-2012, 05:46 AM #14
(01-09-2012, 04:53 AM)dieselmeken To mee it sounds like a balance problem. It runs on all 5 cylinders what I can hear. Maybee Tom has another opinion.
thanks Goran, and sorry for stealing your post Wink
cho
tomnik
01-09-2012, 07:06 AM #15
I agree with Göran- balancing.
(I mixed up the cyl. 5 issue with another post).
Assuming that the pump has to go to a diesel shop for proper adjustment anyway, you could measure the glow plug voltage OUTPUT when the engine is running and the glow plug common socket is disconnected.
In the socket (where the it goes into the glow plug relais) you can take the voltage (mV only) and compare the individual cylinders among each other.
Then you carefully rotate the flange of the cylinder with lowest voltage.
The other voltages will then change also but in general it should be better than before.
This is not according to any correct instruction but can help.
Can you check timing with a strobe lamp at a Bosch service to confirm what the guys did?
Tom
I have to do some more tests but the MW elements will be >6.5mm.
tomnik
Tom
cho
01-09-2012, 08:52 AM #16
(01-09-2012, 07:06 AM)tomnik I agree with Göran- balancing.
..of the pump I suppose?
(01-09-2012, 07:06 AM)tomnik Can you check timing with a strobe lamp at a Bosch service to confirm what the guys did?
will do that and report back
(01-09-2012, 07:06 AM)tomnik I have to do some more tests but the MW elements will be >6.5mm.
that's great, If I m not wrong in that case I can hold my
default garret turbo (maybe add some 65mm exaust...) .... what kind of HP can be expected
in that case...?
regards
chO
This post was last modified: 01-09-2012, 08:53 AM by cho.
cho
in that case...?
regards
chO
