STD Tuning Engine turbobanditen VS kkd manifolds
Kennobi75
12-24-2011, 01:47 AM #1
does anyone have experience with turbobanditens exhaust manifolds ?
http://www.turbobanditen.se/shop/
  1. 93 300TDTMyna
  1. 05 S211 280cdi
Kennobi75
  1. 93 300TDTMyna
  1. 05 S211 280cdi
iheartboost
12-24-2011, 02:51 AM #2
holy crap!! thats really expensive! ill take the KKD manifold just cuz its like 100 bucks cheaper
00 Mustang gt drift car
iheartboost
Kennobi75
12-27-2011, 04:37 PM #3
what are kkd spec ? does anyone know ?
turbobanditen specs are 42x2mm pipes, twin entry, 60mm wastegate
  1. 93 300TDTMyna
  1. 05 S211 280cdi
Kennobi75
  1. 93 300TDTMyna
  1. 05 S211 280cdi
antonmies
Go MPR
59
12-28-2011, 08:14 PM #4
KKD has 38mmx2mm, but can also be any other size you might need. Other common size is 42,4x2,6mm. Manifold can be twin or single entry and wastegate option as per customers requirement.
I always suggest to go with the smaller pipe for much better response. Does it flow enough? We've seen 1000hp gasoline engines using that size, so yes it does Wink
His manifolds are mild steel and he's certifies welder for any material (except titanium, dunno for sure though) and would be able to legally weld any component to a nuclear power plant for example. Dunno about that for the Chinese MoFo, who made Turbobandit's manifolds.
Not saying they are bad though! But I feel KKD is more at the safe choice side and fully customisable _prior_ to welding.
Hope this helps.
antonmies
Hope this helps.
bad3gakk
om605 - kkk27 - w124
52
12-28-2011, 11:09 PM #5
Mild steel is the good shit, stainless does not handle the combination of temperature variables and mechanical tension, as mild steel does. Where stainless cracks, or become so stiff, that bolts crack, mild steel just flexes...
bad3gakk
jeemu
457
12-29-2011, 05:48 AM #6
KKD make alot manifolds around the world so those are used outside of Finland as well Wink what i know all been satisfied the guality at KKD.
He are made those alot for just racing use as drifters or drag race cars.
jeemu
antonmies
Go MPR
59
12-29-2011, 11:54 AM #7
Just don't put any wrapping on a mild steel manifold.
The debate for mild vs. stainless is not so straight forward as many thinks. The austenic form in 304 and 316 suits high temperature applications better than mild steel and withstands heat better in chemical point of view. And they are prone too crack if the larger expansion isn't taken in account in the flange and overall design. The most important thing for any manifold is to support the damn turbo!
And for any manifold, It's not the point 'if they crack' but 'when they crack'.
I would like to make mine of 309 or 309S as it has good chemical properties, doesn't need root gas. Basically it has the good points from both worlds (sst - mild)
antonmies
majesty78
12-29-2011, 01:19 PM #8
A pitty either of them make a manifold for OM613....
majesty78
antonmies
Go MPR
59
12-29-2011, 01:40 PM #9
Kalle makes anything. Just provide him a gasket to draw the flange and a simple jig or even measures how much space there is, and he'll make it.
antonmies
majesty78
12-29-2011, 02:00 PM #10
Good to know Anton ;-)
But as you know I will have very little time for playing around with my car in the next month... :-(
majesty78
Kennobi75
12-29-2011, 04:00 PM #11
Ok,, thanks for the info !! Smile
  1. 93 300TDTMyna
  1. 05 S211 280cdi
Kennobi75
  1. 93 300TDTMyna
  1. 05 S211 280cdi
Kennobi75
01-02-2012, 11:04 AM #12
just for the record,
turbobanditten say they make their manifolds in sweden or russia..no china product, at least thats what they say..
i think they are russians living in sweden.
  1. 93 300TDTMyna
  1. 05 S211 280cdi
Kennobi75
  1. 93 300TDTMyna
  1. 05 S211 280cdi
antonmies
Go MPR
59
01-02-2012, 04:50 PM #13
Yes they are (Russians that is). To be honest, it's no matter where the product is being made but that matters if the QC is good or even exists...
antonmies
kkdmotorsport
02-16-2012, 12:50 AM #14
(12-24-2011, 01:47 AM)Kennobi75 does anyone have experience with turbobanditens exhaust manifolds ?
Looks China manifold Confused
This post was last modified: 02-16-2012, 04:25 AM by kkdmotorsport.
kkdmotorsport
Kennobi75
02-16-2012, 12:59 PM #15
Ok,, good to know Smile
i choose your kkd manifold Smile
  1. 93 300TDTMyna
  1. 05 S211 280cdi
Kennobi75
  1. 93 300TDTMyna
  1. 05 S211 280cdi
erling66
SuperDieselVan
294
02-16-2012, 02:38 PM #16
(12-29-2011, 11:54 AM)antonmies Just don't put any wrapping on a mild steel manifold.
Why? will it get too hot and crack or twist?
HuhCoolTongue
erling66
HuhCoolTongue
2996
02-21-2012, 02:18 PM #17
Please tell us more about not wrapping KKD manifolds. What would you suggest, a coating of some type?
Would it be possible for Kalle to use 304, 309 or 309S instead of mild steel since he is likely certified for those materials?
I would much rather buy a manifold from KKD rather than Turbobanditen, I just wish KKD could use some grade of stainless, then I could use thermal wrapping on the runners. I used thermal wrapping on other project cars, and it does improve response, documented from datalogs before and after the wrap from less thermal loss, and lowers ambient temperatures within the engine compartment. I do not care about how one looks over the other, it should be mentioned Wink
2996
majesty78
02-21-2012, 04:50 PM #18
This confuses me a little bit.
Actually, at least from what I know referring to turbo technic, most of cracking in turbine housings occur due to fast changes between hot and cold.
So from this point of view, a wrapping should actually help to prevent cracking because of the heat isolation effect.....???
majesty78
Savitas
02-23-2012, 01:10 AM #19
(12-28-2011, 08:14 PM)antonmies KKD has 38mmx2mm, but can also be any other size you might need. Other common size is 42,4x2,6mm.
42.4 mm is outside or inside pipe diametre? Thanks
Savitas
EDH_Performance
02-23-2012, 07:34 AM #20
(02-23-2012, 01:10 AM)Savitas
Outside is the standard measurementWink
EDH_Performance
Savitas
02-23-2012, 08:39 AM #21
(02-23-2012, 07:34 AM)EDH_Performance
Thanks, I just want to be sure Wink
Savitas
2996
02-28-2012, 01:36 PM #22
So, can or will KKD construct manifolds in anything other than mild steel, and if properly painted with a high temperature coating, can the mild steel Kalle uses withstand thermal wrapping? A paying customer would like to know Cool
2996
Kennobi75
03-08-2012, 04:24 AM #23
recieved my 42.4 mm kkd manifold today.. it sure looks nice Smile
  1. 93 300TDTMyna
  1. 05 S211 280cdi
Kennobi75
  1. 93 300TDTMyna
  1. 05 S211 280cdi
Booster
03-13-2012, 03:36 PM #24
(03-08-2012, 04:24 AM)Kennobi75 recieved my 42.4 mm kkd manifold today.. it sure looks nice Smile
Could you post some pictures please??
What turbo are you putting on it?
Cheers
Booster
Cheers
03-15-2012, 06:34 PM #25
On the website, that 2nd from left blue benz with red star. I've seen utubes of it running. It is the nuts.
Robert_UAH
03-16-2012, 02:46 PM #26
(02-16-2012, 02:38 PM)erling66
From what I remember, wrapping usually promotes rust on the manifold.
Robert_UAH
07-12-2016, 05:10 PM #27
Anyone have a link to the manifolds on kkd's site?
124diesel
07-12-2016, 11:21 PM #28
(07-12-2016, 05:10 PM)winmutt Anyone have a link to the manifolds on kkd's site?
From what I remembered they don't have a section for that. I worked with them directly through email. I would suggest going with a different company. After a two month delay, incorrect manifold design ( Sent pictures of requirements/ design and a manifold that had a warped flange you could say I wasn't too happy. Cheap heat treatment that would scratch off too easily with no effort that I had to sand blast and ceramic coat.
Obviously everyone has different experiences with the same companies but wanted to give my .2 cents.
124diesel
