STD Other Projects Scout Terra with a 617,SM465, 203/205 doubler, lockers front and rear
Xyz12383318
01-01-2012, 05:20 PM #1
I am building an old Scout Terra with a Mercedes 617. I am going to be running an SM465 transmission and a 203/205 doubler. The axles are Dana 44's with a detroit locker in the rear and an Ox locker in the front. I will probably run 35" tires. I will daily drive it, as well as take it to Moab for some offroading.
So far I have removed the body from the Scout and sanblasted.everything. I coated.everything with Por15 to prevent.rust. I built motor mounts and have the engine sitting in place adapted to the motor. The 203 and 205 are sitting on the bench waiting to be conncted. I would.like to buy the oil filter adapter I have seen on this sight.
Xyz12383318
dieselboy
Rotatin 5500 times a minute
680
01-02-2012, 01:56 AM #2
Nice! Any pics of the thing yet?
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
Purplecomputer
Slowness 220D
897
01-03-2012, 12:40 AM #3
I think thats an awesome choice for a car Big Grin
let me know when you want to sell it Tongue
Purplecomputer
Xyz12383318
01-05-2012, 09:53 AM #4
(01-03-2012, 12:40 AM)Purplecomputer I think thats an awesome choice for a car Big Grin
I am having trouble getting pics.from my Android to download to.the forum. It says they are too big.
Xyz12383318
01-06-2012, 10:24 PM #5
Are you attaching them here? I usually re-size to 1028 x 764 before uploading
Xyz12383318
01-08-2012, 07:04 PM #6
[Image: 4a84598a.jpg]
[Image: 2011-09-03172442.jpg]
[Image: IMG_1229.jpg]
[Image: 2011-12-21205821.jpg]
[Image: 2011-12-21205840.jpg]
[Image: 2012-01-03205637.jpg]
The first picture is of the victims. The Benz motor is bolted to an SM465. I am still working on my 203/205 doubler. The Scout was sandblasted, and I covered it with Por15. I have the motor in and mounts welded up. I am building a cage in the Scout and thought it would be cool to put it in between the panels. I also stretched the Scout and had to move the rear wheel wells. I must say My projects get carried away. Here is a picture of my $bt Scout I am just finishing up. It is a 4BT, NV4500, NP205, Dana 44's with an ARB locker in the rear. Custom cage, bumpers, sliders, etc...
[Image: 2012-01-08093441.jpg]
I sure would like to find a Mercedes diesel guru close to me. I am living in Idaho and Utah depending on the week.
Xyz12383318
01-08-2012, 08:02 PM #7
Looks good!
Looks good!
Xyz12383318
01-10-2012, 08:24 AM #8
I am a little concerned. The adapter plate on this Scout does not.allow me to bolt in the stock oil pressure sending unit. Does anyone know what size that hole is or a 90 degree fitting that will fit it? I contacted a member here via pm about buying a block off plate for the oil filter but have had no response. Does anyone have suggestions to over come this problem?
Xyz12383318
Xyz12383318
02-09-2012, 09:02 PM #9
I have put a few hours into the Scout. I installed the clutch, as well as the 203/205. I have been working on body work. Here are a few pics!
[Image: 20120209_183027.jpg]
Here is my triple stick shifter for my t-cases
[Image: 20120209_183039.jpg]
Here is the crossmember I fabricated for the t cases
[Image: 20120209_160725.jpg]
Here it is in place.
[Image: 20120209_183055.jpg]
Another shot.
[Image: 20120209_183103.jpg]
The motor is looking a little dusty from body work. It looks like the radiator is going to hook right up to the stock hoses. I have the oil cooler hoses run. Now I need to get the acceleration pedal linkage to work. Then I will install the steering wheel, steering, etc... I am still not sure how I am going to plug off the hole where the oil sending unit was. I would like a spin on.
This post was last modified: 02-09-2012, 09:07 PM by Xyz12383318.
Xyz12383318
Another shot.
