STD Tuning Engine CAT Turbocharger CAT320B on a OM617
serverman777
01-11-2012, 08:53 PM #1
Ok here we go...
I got myself a CAT30B Caterpillar Tubro Changer today. It looks to me to have a T3 flange on it. So it should blot up to my exhaust manifold with ease. But... It dosn't have a wastegate. From my understanding it has to have a wastegate. So how do I mount a external wastegate onto it? Please refer to my photos.
[img][Image: aYoRX.jpg][/img]
[img][Image: YQrDJ.jpg][/img]
[Image: DMkIB,aYoRX,sqGW9,9Cqst,YQrDJ#0]
[img][Image: sqGW9.jpg][/img]
[img][Image: 9Cqst.jpg][/img]
[img][Image: DMkIB.jpg][/img]
This post was last modified: 01-11-2012, 08:54 PM by serverman777.
'84 300 SD w126 Race Car Wink
'85 500 SEL w126 Scraped
serverman777
Ok here we go...
kmaser
Turbocharged G-Wagen
125
01-11-2012, 10:00 PM #2
Yes you would need to mount an external wastegate, no CAT engine has an internal wastegate
kmaser
serverman777
01-11-2012, 10:15 PM #3
I been trying to find a how to guild on porting for a external wastegate and haven't found anything.. Can you give me a quick walk though.
serverman777
01-12-2012, 01:06 AM #4
Hes got it under control now! Cool
dieselboy
Rotatin 5500 times a minute
680
01-12-2012, 02:04 AM #5
(01-11-2012, 10:00 PM)kmaser Yes you would need to mount an external wastegate, no CAT engine has an internal wastegate
Lol wat? When was the last time you worked on a cat? 1970?
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
01-12-2012, 04:24 AM #6
Could you possibly get some sort of valve that will open (at whatever pressure you want) and vent boost through the overboost sensor port on the intake manifold into the exhaust post-turbo or something? Just a thought
kmaser
125
01-12-2012, 10:04 AM #7
(01-12-2012, 02:04 AM)dieselboy
Yes, 1970 was the last time I worked on a CAT how did you guess??? Lol
I was at work and was only thinking about it in terms of what I work on ( stationary natural gas Engines ) not the smaller diesel's.. My bad!
kmaser
01-12-2012, 10:51 AM #8
I don't know if your going to have enough room for this with that turbo
this is an option it bolts between the turbo and exhaust manifold
look up t3 flange blow off valve adapterBig Grin
serverman777
01-12-2012, 11:05 AM #9
(01-12-2012, 10:51 AM)willbhere4u I don't know if your going to have enough room for this with that turbo
Found that thing last night on ebay. I think I got room for that. But I need to find a wastegate that can take up to 20psi. like 38mm or somthing
Ok there is my question. Like I been looking at different gates. Like they have different springs that you can get for them, but like they are rated for like 14 psi. So is that max 14 psi or min 14 psi..
http://www.ebay.com/itm/38MM-Turbo-Stain...566wt_1179
like this one.
This post was last modified: 01-12-2012, 11:16 AM by serverman777.
serverman777
like this one.
serverman777
01-12-2012, 12:50 PM #10
Ok Im back....
This is my plan right now...
Start off with this flange
http://compare.ebay.com/like/18074433371...si=y&cbt=y
With this wastegate
http://www.ebay.com/itm/GSP-44MM-GT-SERI...685wt_1021
With these to take my 38mm wastegate flange to 44mm to fit the bigger wastegate
http://www.ebay.com/itm/Adapter-Tial-38m...1115wt_946
And then with this dump pipe
http://www.ebay.com/itm/35mm-38mm-Wasteg...129wt_1179
serverman777
Ok Im back....
With this wastegate
01-12-2012, 01:06 PM #11
Maybe use the EGR as wastegate?
serverman777
01-12-2012, 01:51 PM #12
What? Explain please
serverman777
01-12-2012, 01:58 PM #13
shit, he's talking about dumping it into the exhaust mani at the egr port. Not a bad place for it. Just need to figure out how to connect to the mani. Kinda an odd little nipple thingy there.
serverman777
01-12-2012, 02:13 PM #14
I think thats dumb. Dumbing exhaust gasses back into the system. Nah.
serverman777
01-12-2012, 02:29 PM #15
No.....
It is dumping what is considered extra intake air into the exhaust mani. That's where its going anyway. Unless you have the screamer Wink
I wonder what is the difference if the extra boost goes into that exducer (like in the exhaust mani or in that t3 adpater thing with the hole in it)
or just out the exhaust pipe or a screamer where it skips the back half of the turbo all together.
No.....
serverman777
01-12-2012, 02:31 PM #16
I think im going to do a screamer.
serverman777
01-12-2012, 02:34 PM #17
Yah, sounds awesome. PS those pictures are way too big, it is making my little computer have a heartattack ack ack ack
01-12-2012, 04:07 PM #18
Use the stock EGR as a wastegate. Just unhook it from the intake manifold and set it up so that when you hit 13psi a vacuum switch allies vacuum to the EGR actuator.
01-12-2012, 06:29 PM #19
That flange you posted a link 2 converts from t3 to t25 flange Huh
You probably want a t3-t3 style I assumeBig Grin
This post was last modified: 01-12-2012, 06:29 PM by willbhere4u.
01-12-2012, 07:22 PM #20
(01-12-2012, 04:07 PM)Simpler=Better Use the stock EGR as a wastegate. Just unhook it from the intake manifold and set it up so that when you hit 13psi a vacuum switch allies vacuum to the EGR actuator.
he told me he wants 20psi Wink
serverman777
01-12-2012, 07:59 PM #21
At least 20 PSI
(01-12-2012, 06:29 PM)willbhere4u That flange you posted a link 2 converts from t3 to t25 flange Huh
My Bad
Edit
This one
http://www.ebay.com/itm/T3-T3-CAST-38MM-...%26ps%3D54
This post was last modified: 01-12-2012, 08:00 PM by serverman777.
serverman777
At least 20 PSI
My Bad
Edit
This one
01-13-2012, 01:55 AM #22
Haha! You guy are out of your fuckin mind!
I mean what Simple=better said
once you hit desired psi, vacuum is applied to EGR that would "waste" boost into the atmosphere
01-13-2012, 09:13 AM #23
No no no!
The EGR would be blocked off on the intake side. The exhaust side of the EGR would still be hooked up, but instead of dumping into the intake, it dumps to atmosphere. When you hit the desired boost level (13, 20, 78) somehow activate a vacuum switch to open the EGR, which now vents the pre-turbo exhaust to atmosphere.
No no no!
01-13-2012, 09:46 AM #24
so all the mechanics are hooked up the same way. Just that 'waste' boost goes through the intake mani --> egr valve --> exhaust mani --> exducer ---> tailpipe/atmosphere
right?
right?
01-13-2012, 10:46 AM #25
Nope.
To slow the turbo, you want to vent pressure pre-turbo. The easiest way to do that is use the existing EGR valve and replumb it to vent the pre-turbo exhaust to atmostphere. The boost decreases because the turbo then slows down.
If you were to run it as a blow-off valve you would be wasting boost, and keeping the turbo working harder than it needs to constantly.
Nope.
serverman777
01-13-2012, 10:48 AM #26
I like the wastegate idea better than the EGR valve idea.
serverman777
01-13-2012, 11:52 AM #27
If you don't mind buying a wastegate hell yeah! I like to make things the cheap not-necessarily-right-way :p
serverman777
01-13-2012, 12:09 PM #28
I got money to spent
Do you guys think that turbo will make more than 20 PSI?
This post was last modified: 01-13-2012, 12:11 PM by serverman777.
serverman777
01-13-2012, 12:58 PM #29
I'm sure the turbo is!
But probably not without a custom injection pump and some serious cylinder head port work
serverman777
01-13-2012, 01:35 PM #30
Yes that leads me to my next set of questions. Custom injection pumps and port and polish.
serverman777
01-13-2012, 03:53 PM #31
Im still trying to figure out what the advantages of the CAT turbo will be over the stock one?
dieselboy
680
01-13-2012, 08:36 PM #32
My hy35 hits 20psi with the wastgate unhooked.
I cannot remember the exact size on the 320b but the compressor inlet looks odd.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
serverman777
01-19-2012, 10:56 PM #33
Anybody got a idea how to get a 44 mm wastegate onto the port for the egr valve thats on the exhaust manifold? Anybody want to make me something?
serverman777
aaa
01-20-2012, 05:27 AM #34
Probably could just put a v-band wastegate on it.
aaa
led-panzer
01-20-2012, 07:42 AM #35
Do you have a map for that turbo? Or other info? You could take it apart and measure the wheel inducer/exducer + number of blades would give you a very rough estimate. And finding/figuring out the turbine housing AR will give you a rough idea of how fast it will spool/whether you need a wastegate at all
1985 300D 280,000 miles RIP
led-panzer
serverman777
01-20-2012, 12:14 PM #36
Cat dosn't give out any info or specs on there turbos Sad.... I have it apart right now and could measure the ind/exdcer. Can you explain more about the measurements
serverman777
