4 Speed Questions
4 Speed Questions
This will be an ongoing thread with many questions...hopefully there are some answers out there.
This is for a 4 speed manual going into my 300TDT wagon....hopefully just a bolt on operation since the bell-housing is correct for the 3.0T
#1.....What bolts have people used to attach the pressure plate to the flywheel??? I’ve been trying to find pictures and specifics but have had no such luck. Anybody know?
Oh great thanks. I noticed most of the drivetrain bolts are 8.8. I.e. the six on the torque converter. Schweet.
#2. How do I make a square peg fit into a rectangular hole? The mechanical speedo on my wagon is a square peg, while the female entrance is a rectangular hole. Any simple solutions?
I scoped about a dozen different w123s, at the PaP yesterday, with no such luck. That was my original plan. I found a w123 with a 4 speed still intact, but it had a later all aluminum manual. Wrong cable yet again.
I will continue to scope, but at the same time I will start formulating a plan of action.
Wow I'm lucky if I find one or two w123's at the local PaP lol, we'll see how they are this trip though
It's gonna work anyway - speedo cable wise.
If not here's a 'trick' - take a beer can, drink beer first, cut a small patch, fold it in two, and place the square in the fold. Mount speedo cable with said mod.
Naturally the best route would be to order the correct speedo cable (they're not very expensive)
Ooooo good call on ordering the right speedo cable. I will look into that. Meanwhile I will prepare for whatever by drinking that beer. Better to be prepared than not.
(02-07-2012, 05:28 PM)w123love Oh great thanks. I noticed most of the drivetrain bolts are 8.8. I.e. the six on the torque converter. Schweet.
(02-08-2012, 06:55 PM)dropnosky My ground down speedo cable never had a single problem
Shhhhh....(don’t tell my dad....but i’m going to do the beer can trick!) lol
check out this thread, lots of measurements in it-
http://www.superturbodiesel.com/std/Thre...four-speed
Question #3 I think...
Does anyone know of a good write up for wiring the reverse lights to the 4-speed shifter?
(02-18-2012, 11:33 PM)w123love Question #3 I think...
(02-19-2012, 02:15 PM)dropnosky(02-18-2012, 11:33 PM)w123love Question #3 I think...
Easy, 4 wires going to the auto transmission that you pull back inside the car. Wire the violet and white and solid violet to your neutral safety swich on the pedal (or together to bypass not in park safety switch), and the other two wires (forget the color) are the reverse switch lights, wire directly to the swith on your shifter
See that is the problem. I bleed the system. Fluid would fly out of the slave’s bleeding nipple when the clutch pedal was depressed. With the nipple closed, the the slave cylinder would push its rod. So now the problem is inside the transmission. (I believe)
Just a note: When I was connecting all the clutch lines, the brake fluid would flow very easily. (Just gravity fed) I would make a connection, and then 2 minutes later the fluid would start dripping out the open end. This happened all the way to the slave cylinder. Then it started dripping out of the slave. I bleed it a little bit, but more and more fluid was coming out so I called it good.
