STD Tuning Engine HE221W ( HX27 HOLSET) 617A?
kmaser
Turbocharged G-Wagen
125
02-15-2012, 04:30 PM #1
Does anybody have any experience with an HE221W ( HX27 ) Holset turbo on an OM617A. I have Tomniks 6.5mm elements installed and looking for a turbo that spools close to stock but not choke the top end so much? I have also looked at HX30 but just seems to me that it would spool too slow but I'm not sure what too look for as far as flow rates etc.. I can't find much if any info on turbos for modified OM617's, most of the info is different turbos with stock pumps. If I didn't need to get more flow at highway speed (3500rpm) and was only off road I would stay with the stock turbo but its too choked and making too much heat at that RPM. My turbo is done and I need to get it back on the road ASAP. I would love some inputHuh
Thanks
kmaser
Thanks
02-15-2012, 06:01 PM #2
I'll sell you my HY30W with the t3 adapter I made for it. It is slightly smaller than the HX30W. With 6.5 elements you should be able to turn that potato easily enough.
kmaser
125
02-15-2012, 08:05 PM #3
How did it spool on your engine and how much do you want for it, what kind of condition/shaft play?
kmaser
02-16-2012, 09:53 AM #4
It spools well on the stock 603 pump. Its in great condition, no play. It is still mounted on the car, I am trying to get a hold of a hx30w to replace it with. $200 with adapter (its t25 flange)?
