STD Tuning Engine Alternator Clutch Pulley Replacement
zeeman
02-29-2012, 11:15 PM #1
Anyone know the proper way to remove the alternator clutch pulley. It appears to be pressed on instead of being held on with a nut. I am updating my 606 alternator to a 150 amp. and need to change pulleys. Is there a special tool for this or just a puller?
zeeman
dieselmeken
03-01-2012, 02:46 PM #2
(02-29-2012, 11:15 PM)zeeman Anyone know the proper way to remove the alternator clutch pulley. It appears to be pressed on instead of being held on with a nut. I am updating my 606 alternator to a 150 amp. and need to change pulleys. Is there a special tool for this or just a puller?
Special tool is required for that.
dieselmeken
zeeman
03-01-2012, 06:46 PM #3
(03-01-2012, 02:46 PM)dieselmeken
Pricey tool or dealer item?
zeeman
03-01-2012, 10:28 PM #4
I think this is the tool you need. If it's not the correct size but similar tool.
http://www.ebay.com/itm/ALTERNATOR-PULLE...1504wt_754
zeeman
03-02-2012, 02:22 AM #5
(03-01-2012, 10:28 PM)DeliveryValve I think this is the tool you need. If it's not the correct size but similar tool.
Thanks for the tip, got it ordered up.
zeeman
