STD Tuning Drivetrain diff ratios help
diff ratios help
diff ratios help
03-06-2012, 09:54 AM #1
hy guys can u help me to check about differential ratios, need to swap mine for bigger one and dont really know how to recognize them.
got a 124.126 .
regards
got a 124.126 .
regards
03-06-2012, 04:29 PM #2
(03-06-2012, 09:54 AM)barrote hy guys can u help me to check about differential ratios, need to swap mine for bigger one and dont really know how to recognize them.
got a 124.126 .
regards
For the w124, take a look on the lower right corner of the rear cover.
There should be numbers stamped on the diff case along the edge of the cover. Those numbers should have the ratio.
got a 124.126 .
regards
cho
03-07-2012, 09:18 AM #3
got a 124.126 .
regards
your options are:
w124
220 E / E 220 (124.022): man 3.67, aut 3.07
230 E (124.023): 4man 3.27, 5man 3.27 (up to 8.89) 3.46 (from 9.89), aut 3.27
260 E (124.026): man 3.27 (up to 8.89) 3.92 (from 9.89), aut 3.27
260 E lang (124.027): man 3.92, aut 3.46
300 E (124.030): man 3.07 (up to 8.89) 3.67 (from 9.89), aut 3.07
300 CE (124.050): man 3.07 (up to 8.89) 3.67 (from 9.89), aut 3.07
300 TE (124.090): man 3.27 (up to 8.89) 3.92 (from 9.89), aut 3.27
200 CE / E 200 C (124.040): man 3.67, aut 3.27
220 CE / E 220 C (124.042): man 3.67, aut 3.07
250 D / E 250 (124.125/124.126): man 3.67, aut. 3.07
E 250 D turbo (124.128): man 3.46, aut. 2.65
cheers
cho
got a 124.126 .
regards
your options are:
w124
cheers
hannes_s
03-07-2012, 12:58 PM #4
Google "w124 gear ratio" -> http://et.mercedes-benz-clubs.com/mediaw...ie:W124/en
Find your model, select Transmission and Performance Wink
hannes_s
03-07-2012, 03:01 PM #5
thanks guys,
well in the junk yard , the only thing i can see sometimes are these mercedes serial number, that´s what i need to identify.
i´ll check it out. thanks
thanks guys,
