2006 CDI Immobilizer
In doing a 2006 E-320 CDI custom engine installation I have a problem with the ECU. As I understand I need the ECU, dash cluster and smart key to make it all work in a stand alone application.
The immobilizer cannot be deleted, although if you have the vin# of the car the ECU came from, a friendly Mercedes dealer can make a smart key for you.
This gets the engine started, then I understand the dash cluster must be from the same car in order for the odometer to function because the ECU stores the numbers.
I have read were the cluster was changed with a used unit and everything worked fine except for the odometer.
Is it possible to reprogram the cluster to operate properly with the ECU. I am able to have the transmission function removed to use a different transmission. Am I correct on my information so far.
You will need the CDI control unit, the EIS(electronic ignition switch) control unit, smart key, front SAM (signal acquisition module) for starter engagement, accelerator pedal for throttle signal, BCM (battery control module) for engaging the serial interface on alternator, and Transmission control unit if using a 722.6 automatic. The odometer reading is stored in the EIS control unit.
To my knowledge you should not have to worry about an instrument cluster for your application unless you want that style cluster for the project and the check engine light indicator. To order a smart key you will need the VIN, proof of ownership (title), and drivers license.
(03-14-2012, 07:52 AM)MB TECH You will need the CDI control unit, the EIS(electronic ignition switch) control unit, smart key, front SAM (signal acquisition module) for starter engagement, accelerator pedal for throttle signal, BCM (battery control module) for engaging the serial interface on alternator, and Transmission control unit if using a 722.6 automatic. The odometer reading is stored in the EIS control unit.
also I would grab the steering lock, shifter assembly, and ESP control unit just in case you run into problems with gear selection with an automatic.
The limp mode originates from the trans control unit, however when it is detected, the CDI module throws fault codes for the limp mode, I am not certain if it hinders anything on the engine side or if it is simply just fault codes.
(03-16-2012, 01:24 PM)MB TECH The limp mode originates from the trans control unit, however when it is detected, the CDI module throws fault codes for the limp mode, I am not certain if it hinders anything on the engine side or if it is simply just fault codes.
