4 Speed Swap S123
4 Speed Swap S123
So I got my wagon all back together after a rod gave way with a low miles engine which runs great, with the old automatic and well it decided to work for about a mile then the main pump went out ( no forward or reverse gears & no pressure in the cooling circuit ) so now I've secured funding for a manual swap + sls delete kit.
So my research tells me,
Then engine I have has the emissions stuff on the side of the IP and the air recirculation valve on the turbo. So I assume the engine is a 85. So I can either have a bearing shaved down 1mm (winmutt) or freeze it and bang it in.
Both flywheels ( auto & manual ) will have to be taken down and matched for balance also take note of witness marks even make some of your own.
The shifter linkage needs the thread extended 6" and then cut 4" off the linkage (depending on year transmission can be different)
The transmission cross member needs a new hole drilled in it at the bare minimum
The driveshaft needs to be shortend by 4" and have the 240d flange put on the end & balanced.
Anything else? Really would be nice if I can get this thing working so I can drive it...
You could get a break cylinder hone and bore out the crank it may take awhile but should be able to open it up
(03-17-2012, 03:39 PM)Kozuka ...
If you have the crank problem, you could also us a GM pilot bearing and machine a bushing for the outside, since its smaller overall. The ID on a lot of 80s models are the same at the MB input shaft dimension.
Id do that over the freezing method personally. Once the frozen pilot bearing heats up its just going to be expanding and reducing the life of the bearing since the space is still to small
It's located between the oil filter housing and the engine block. The numbers are right below the cylinder head.
(03-18-2012, 06:17 PM)Kozuka 617 952 12 095 696
I kinda like the boring out the crank idea the best so far since its almost there already and it keeps it stock and ends headaches, no machine shop access that I don't have to pay for. Already the flywheel will have to be balanced would rather not have a custom bushing made unless it could be done for like $30 or less. My experience with machine shops is you pay a premium unless you know someone, which I do not.
Use a power drill and some kind of fluid usually you use break fluid for break jobs but a cutting oil should work best it may take a while to open it up enough 15-20 my guess I would get a really good digital caliper to measure it and the bearing and stop just short of the bearing size by a couple thousandths
(03-17-2012, 03:39 PM)Kozuka Both flywheels ( auto & manual ) will have to be taken down and matched for balance also take note of witness marks even make some of your own.1) highly likely the auto flywheel is already neutral (or really close), but definitely match mark it and have it checked and the new one matched
Well, a little update..
Grinding out the crank took 3 days, 3 tools, & three sets of stones. Because of the position of the hole & shit tools, you really need a dial bore gauge. Probably could of got a bearing shaved or a s10 bearing & custom bushing for cheaper.
Don't buy LUK clutches because the pressure plate doesn't fit without modding... ( which I did )
The thread for the clutch master & slave is M12x1.0 & the thread for the shifter linkage is M10x1.5.
Went with AN -4 for the clutch 3,000psi rated. Hope my master works, it shot fluid out the top when I compressed it.
The machine shop did great, 156 grams out of balance. Started in neutral, smooooth....
I broke one of the aluminum shifter rod ends trying to get it adjusted to fit, took the one off reverse. Today I should receive new bushings & clips.
I'm hoping that tomorrow I will get my clutch line stuff so I can get this sucker tested out.
Reverse situation is I have to probably bend the end 30 or so degrees, lengthen the thread, & shorten it a few inches.
(04-02-2012, 04:46 PM)Kozuka I broke one of the aluminum shifter rod ends trying to get it adjusted to fit, took the one off reverse. Today I should receive new bushings & clips.
Well it works, going to have to take my driveshaft to be balanced defiantly. My master shoots fluid when it wants too, going to get a rebuild kit. The parts diagram on epc is rather confusing for the shifter linkage. I got them backwards haha. Need my SLS conversion & a spring compressor now... Well & reverse..
