Oil return - blowing turbo seals...
If the passages are large enough, yes. If I remember correctly the drain on my 617 was ~ 3/4" in diameter from the turbo to the block.
I wouldn't use a banjo to restrictive, just use some AN -10 there are fittings for the turbo drain. No kinks, strain down, weld a bung onto the oil pan. Call it good. You might want to look into a restrictor on the feed side of the turbo if it still is blowing out the seals.
