Ampage glow plug relay ?
....... google has failed me on this one.
Troubleshot the glow plug circuit on my 300D, faulty relay.
The relay was not immediately replaceable via my local parts store, so as an interim measure, I picked up one from the local electronic store for like 10 % of the online replacement part.
It works fine, although it only has a rating of 20/30 amps, which surprised me. Thought it would melt.
Glow plugs are of the "loop" type, five of them.
I've seen a 70 amp version online of the relay for about 3 €, which I'll probably get out of principle when I eventually upgrade to "pencil" type plugs.
Should mention that I initialize the glow plug system with the old fashioned "pull knob" as opposed to turning the key, thus the "cut out" feature when the engine is running / starter motor engaged on the Bosch etc., type relays is not needed in my case.
A pencil type glow plug is meant to draw 15 - 20 amps ? I assuming the loop type glow plug would draw less, but, and here is where my electrical savvy runs out, do five glow plugs of 20 amps = a draw of 100 amps ? If so, the 60 amp fuse in the circuit should also be dead meat if I upgrade.
Some people have had luck with the cheap 20A relays. A starter relay from an older vehicle can work for you-I recommend Ford/GM but I'm sure there's an inexpensive Netherlands domestic equivalent out there for you.
I have a ford starter relay for my glowplugs
