STD Tuning Engine .60 trim compressor wheel
Torkey
Dirty Diesel
220
04-13-2012, 08:47 AM #1
I tried to install a .60trim compressor wheel last night and it fits great except for the compressor housing. I remember reading that others have done this but can't find the threads.
Do I need to get a different housing or is there a workaround?
Torkey
04-13-2012, 11:04 AM #2
You need to machine out the center of the compressor housing any good turbo shop should be able to do it
Torkey
Dirty Diesel
220
04-13-2012, 10:53 PM #3
Thansk for the info. Took me most of the day calling around before I finally found someone to do the work. Only 5 hours away. I think I will be mailing it.
Torkey
04-14-2012, 10:41 PM #4
cool good luck take some pics when you get it done!
Torkey
Dirty Diesel
220
04-24-2012, 03:57 PM #5
Got the .60 trim wheel installed. Really like it. Taking it to the dyno on Friday to see how much it helped.
Torkey
04-24-2012, 09:22 PM #6
cool post some videos
Torkey
Dirty Diesel
220
05-08-2012, 08:51 PM #7
I put it on the dyne and was expecting great results. The car seemed to have so much more horsepower but the results were nada. The car feels better but I think that's due to better throttle response and not pure HP. Any ideas what could be going on here?
Torkey
05-08-2012, 10:31 PM #8
You need more fuel to go with that extra air!! Right now its probably just building more boost faster, so it will have the same amount of HP but it will just come sooner. This is my theory anyway, I could be wrong
05-09-2012, 01:37 AM #9
Yep you need more fuel.
Read up on Full load thread sticky.
Torkey
Dirty Diesel
220
05-09-2012, 10:41 AM #10
I definitely will be turning up the pump but I'm wondering if the extra HP is being used up pushing the bigger compressor wheel or maybe the waste gate isn't able to keep up and creating back pressure.
Torkey
poleshady
05-21-2013, 03:13 PM #11
where did you get your comp wheel from?
poleshady
mike-81-240d
more like mike-84-300d now
427
05-22-2013, 02:25 AM #12
What were your dyno readings?
mike-81-240d
