swap a 124 w/606NA to 606Turbo?
What doesnt bolt on you can make in a jiffy
Custom intercoolers are cheap, and can be mounted in front of the radiator, with a touch of imagination..
Lots of ppl have done this swap, many have mounted the intake manifold and the IP from the N/A engine onto the DT, and rebuildt the IP with performance elements... Just remember to clog the oil vapor holes in the intake runners..
This way, you will bolt on the throttle, and wount have to fiddle with electronics from the 606.96x wich can be a PITA...
The oil pan, can be used from the N/A engine, so you dont have to fiddle with swaybars etc..
I can only imagine this as an easy and mostly bolt on swap...
Parts from the DT that doesnt fit the w124, you pull from the N/A engine..
Just as easy as fiddling with lego toy bricks
