STD Tuning Engine OM602 Engine swap
OM602 Engine swap
OM602 Engine swap
cover240sx
05-12-2012, 06:39 AM #1
I'm currently swapping my 190e with a OM602 Turbo.
I found the engine in a scrap yard but on the engine they only have the glow plug harness. I also have the ECU.
I was wondering what harness do i need to get to plug on the ECU to make the car start and roll?
I'm also converting it to 5 speed manual so I guess no need for wiring on the transmission.
Thanks in advance!
cover240sx
Thanks in advance!
aaa
05-12-2012, 06:50 AM #2
You only need the glow plug harness to start.
If its a 90 or later 602, the ECU controls the vacuum operated wastegate. If you switch to a pressure-operated wastegate then you do not need the ECU at all.
aaa
cover240sx
05-12-2012, 07:07 AM #3
Well that's a good new.
But if i'm not running a ECU the engine performance will be the same? Cause i'm planning to boost a little bit my engine for racing use. So if I understand enven if I change my IP and the turbo I doesn't need to tune the ECU right?
I'm alway been with gas and slowing going to diesel so I'm kind newb here sorry.
cover240sx
aaa
05-12-2012, 07:58 AM #4
The ECU is for the EGR and wastegate. The rest is totally mechanical.
aaa
