STD Tuning Engine Inj Pumps
Inj Pumps
Inj Pumps
83300d
05-28-2012, 12:39 PM #1
Doing some research on increasing power on my 83 300d, and like most diesel engines tweaking the pump seems to be a common practice. Lots of talk about the M pump, but trying to find one seems to be very difficult, so wondering what can be done to the stock pump.
thanks for taking the time to read this - look forward to your input
83300d
bad3gakk
om605 - kkk27 - w124
52
05-28-2012, 03:15 PM #2
http://www.superturbodiesel.com/std/thread-189.html
This thread seems to be aimed at both mw and m pumps...
Take it easy, and take youre time, and read it all..
Sort out what seems to fit you're pump, take notes, and tune it Smile
If you're confused, this might be the right place to ask for the right way, but read the guide, and try to sort it out for you're self first Smile
I made it, so anybody should be able to do it, with a little focus, willpower and the right attitude, you'll be there in a jiffy! Good luck Smile
bad3gakk
83300d
05-28-2012, 03:20 PM #3
Thanks - looks like all the information I could ever need. Did it make a big difference on your car? Did you delete the ALDA?
83300d
OM616
10mm MW
574
05-28-2012, 04:33 PM #4
(05-28-2012, 03:15 PM)bad3gakk http://www.superturbodiesel.com/std/thread-189.html
Just a word of caution about that thread in regards to the MW/RW pump specifically, the instructions for adjusting the RW governor (used on MW pumps) can get you into trouble very easily, and suggests some improper techniques to try to increase fueling (removing the rack limiter for example), where with the proper combination of adjustments, you can have as much fuel as you want and still have control of it.
Not looking to start a war, just hate to see that information presented as the best for the MW pump specifically.
There is another doc that is just for the MW/RW pump. Many have had better success adjusting and controlling the RW governor using the information in it. Full disclosure, I generated a great deal of the doc, but defer to the comments from those who have used it's information successfully.
The funny part is I do not have a link to it, so if someone can post it that would be cool.
OM616
83300d
05-28-2012, 05:32 PM #6
Look forward to seeing the link when someone can link it. HAHA looks like someone linked it while I was tying this. Thanks
Link doesnt work Sad
This post was last modified: 05-28-2012, 05:33 PM by 83300d.
83300d
ronnie
05-28-2012, 05:52 PM #7
https://docs.google.com/document/d/1QkAv...y=CJXuhs0I
try this one same thing but hope it works
Ok that does not work either. I get back to this later, at least I printed it some time ago but will try to find a link that works.
This post was last modified: 05-28-2012, 06:07 PM by ronnie.
ronnie
kmaser
Turbocharged G-Wagen
125
05-28-2012, 06:53 PM #8
83300D where in southern Alberta are you?
kmaser
83300d
05-28-2012, 07:56 PM #9
South of Lethbridge - 20km from the American border. You?
Ronnie it says invalid document Sad
This post was last modified: 05-28-2012, 08:01 PM by 83300d.
83300d
ronnie
05-28-2012, 09:05 PM #10
https://docs.google.com/document/d/1QkAv...hs0I&pli=1
ok this really should work. I'am better at engines then internet.
ronnie
kmaser
125
05-28-2012, 10:31 PM #11
(05-28-2012, 07:56 PM)83300d South of Lethbridge - 20km from the American border. You?
Medicine Hat, I have tomnik's 6.5mm elements in my MW pump. I have a Mercedes G Wagen that I go out to crows nest pass with.
kmaser
83300d
05-29-2012, 02:52 AM #12
Would love to hear more about the elements and your car sometime. Well have to get together over a wobbly pop or something. I work out in BC so maybe meet at Rum Runners!
83300d
bad3gakk
52
05-29-2012, 03:13 PM #13
I adjusted my M pump 2 rounds, and it made quite a big difference Smile
I didnt remove my alda, i just turned it a few rounds in Smile
Adjusting the rack limiter and such, is not for me, since i didnt feel enough compitent to do so, and wanted to get advice from an experienced friend of mine, but bought a 8mm herlevi pump instead Tongue
bad3gakk
kmaser
125
05-29-2012, 06:49 PM #14
(05-29-2012, 02:52 AM)83300d Would love to hear more about the elements and your car sometime. Well have to get together over a wobbly pop or something. I work out in BC so maybe meet at Rum Runners!
Sounds like a plan, PM me your contact details and I'll let you know next time I'm in that area.
kmaser
