STD Tuning Engine OM603
OM603
OM603
cjcosta
05-31-2012, 09:15 AM #1
Hi everyone,
Another dumb question...
I have a possibilitie to buy a fine w124 TD turbo. The only problem is the damaged engine. Block cracked.
Is it possible to weld it with good fiability?
Can i use a NA engine and use the manifolds and turbo of the damaged engine? This is ok or the NA engine is not identical (like OM617)
Best Regards,
Carlos
cjcosta
Hi everyone,
Best Regards,
Carlos
05-31-2012, 09:16 AM #2
The only real difference is the rods/pistons are weaker in the NA
erling66
SuperDieselVan
294
05-31-2012, 09:51 AM #3
Why is the block cracked? still running? leaking water/oil? Or do you have a hole from a broken rod?
Try to answer this questions and it will be easier to tell you if you can fix it?
HuhCoolTongue
erling66
HuhCoolTongue
