Prechamber seal rings 617 turbo
Hello, We have had the cylinder head rebuilt and they resurfaced the head which was warped.007. They apparently took off .012. I am wondering if anyone might know the correct size of prechamber sealing ring we should order. I talked to engnatwork on P.P and he advised us to make sure and measure regardless of our findings, which is a good idea....but, I do have to special order them from the dealer here so I would like to have it figured out ahead of time what the best choice would be.
I read on here that .008= .2mm so then .012 should be .3mm. If the stock ring is 2.0mm then I should be looking at a 2.3mm sealing ring but maybe I should order the 2.4mm to be safe but I don't want to have it too far away. Thanks.
You need to talk to Phil over at PeachParts-he will help you out on the phone and have the rings way cheaper than a dealer.
