STD Tuning Drivetrain 230 to om617
230 to om617
230 to om617
83300d
06-23-2012, 11:11 PM #1
Found a euro 230 gasser - with I believe a 4spd - and wondering if I could use this trans with my 300d project. W123 chassis so I assume I can use the pedals driveshaft etc, but would have to track down the proper bellhousing?
Thanks
83300d
Thanks
benzguy300
06-23-2012, 11:26 PM #2
No you can't use the transmission starter is in the wrong side you need to find a transmission from a W123 diesel every thing else you can use
benzguy300
83300d
06-23-2012, 11:30 PM #3
Thanks for the quick reply. Guess I keep looking for the trans for a swap.
83300d
06-24-2012, 07:12 AM #4
Depends - is it a 230 or a 230E?
'88 300CD Turbo Coupé - OM603
DiseaselWeasel
benzguy300
06-24-2012, 01:54 PM #5
(06-24-2012, 07:12 AM)DiseaselWeasel Depends - is it a 230 or a 230E?
You are right if it is an older 230 you can use your transmission if it is a 230E you can't
benzguy300
83300d
06-24-2012, 09:03 PM #6
It's a 1977 230 so will check starter location when I drag it home. Thanks
83300d
06-25-2012, 02:37 PM #7
'77 is the old M115 engine with same starter orientation as OM61X Smile Should fit. Depending on age of the OM617, you might still have to change the gearbox flange plate, they changed the centering from screws to dowls, but I'm not sure when. You'll see.
You can vaguely see the difference here; early OM617 & late gearbox:
[Image: 5gkit.jpg]
DiseaselWeasel
[Image: 5gkit.jpg]
benzguy300
06-28-2012, 11:40 PM #8
What was the first year for the 230E? I'm looking for the drive shaft
benzguy300
06-29-2012, 03:30 AM #9
The M102 engine/230E was introduced in 9/'80. As was the new 109HP 200. Both M102 engined cars (230E & 200) share the same drive train.
DiseaselWeasel
