STD Tuning Engine w202 om605 basics
w202 om605 basics
w202 om605 basics
RICHIS
06-24-2012, 09:45 AM #1
started playing with my c250td today how do you run more boost thru the turbo as it seems the turbo is done thru some sort of vacum system is it a case of teeing off the actuator and running a feed to the inlet to get a normal feed for a mbc?
cheers
RICHIS
cheers
Alastair E
Moderator?--Nah...
266
06-24-2012, 04:36 PM #2
Fuelling and Turbo boost controlled by ECU. The wastegate is Vacuum controlled by ECU from vehicle's vac system.
--Messing with the turbo on its own will do nothing--except maybe stuff it up.-- You need Extra Fuel--As well as Extra Air to make more power
--That's all controlled by the ECU....
Re-map is your easiest option.
This post was last modified: 06-24-2012, 05:13 PM by Alastair E.
[Image: 300TDnoplate.jpg]
Alastair E
RICHIS
06-24-2012, 05:32 PM #3
(06-24-2012, 04:36 PM)Alastair E Fuelling and Turbo boost controlled by ECU. The wastegate is Vacuum controlled by ECU from vehicle's vac system.
i can max the fueling out at the turn of a nob just it seems the ecus backing off the boost a fair bit higer in the range plus with other cars ive had mbcs on ive got spool a bit sooner with a nice midrange boost spike.
RICHIS
Alastair E
Moderator?--Nah...
266
06-25-2012, 05:00 AM #4
(06-24-2012, 05:32 PM)RICHIS
Errr----
From that cryptic reply, Sounds like you've modded the F.B. loop to ECU with one of 'em daft variable-resistors!
--REALLY CRUDDY way of doing things......
ONLY way to do it Properly is by a re-map.
The ECU controls the wastegate via the vac system. Its NOT like a common or garden system.
You know...?
--Its best to describe what you have already done IN FULL before asking for help, or we aint got a clue what you're on about, or how to assist!
--By MBCS, I assume some kind of 'bleed-valve' or boost modulator control-valve--Which will NOT function properly with the OM.605 Vacuum controlled system
This post was last modified: 06-25-2012, 05:08 AM by Alastair E.
Alastair E
Errr----
You know...?
RICHIS
06-25-2012, 09:30 AM #5
(06-25-2012, 05:00 AM)Alastair E
Errr----
You know...?
yeh running a 2.k resistor with a 5.5k pot inline .. didnt think there was a easy way to remap these cars thought it was a chip out reflash a new chip then back out job .
looks like il have to do a bit more research then as i will want to run more than std boost with the holset fitted.
cheers
RICHIS
Errr----
You know...?
cheers
