617 Balancing
617 Balancing
of course my friend, if u want to have a smooth engine to rev 6k u have to balance the crankshaft with the pistons and the flywheel, and the other pulley at the front, unless u have a neutral pulley and flywheel just piston rod and crankshaft. anyway no one is doing balance so if u don't, u wont miss nothing special.
(08-26-2012, 12:44 AM)barrote of course my friend, if u want to have a smooth engine to rev 6k u have to balance the crankshaft with the pistons and the flywheel, and the other pulley at the front, unless u have a neutral pulley and flywheel just piston rod and crankshaft. anyway no one is doing balance so if u don't, u wont miss nothing special.
Like Barrote said, for regular driving you're fine, just make sure the flywheel assembly is neutral balanced. If you're making a race motor, you'd better balance it all.
