Bad OM603?
Bad OM603?
Hi, i have a turbo eqipped OM603.912 wich is messing with me!
It started out with a leaky ip and i replaced it with a bad turbo ip then i got another non turbo ip wich is good it spits out fuel about 10 or so inches
And i got the injectors checked and shimmed up to 135 bar and then it started working fine again not as good but still fine, before i gor about 0.8bar when really spanking it now i get 0.4 at the most without wastegate.. And its knocking alot worse and after about 5 minutes of driving its like its got abut 50hp! What could be the problem? Bad fuelfilter or simply a bad enginge?
Thankful for any tips!
