STD Tuning Engine 300d 2.5 IP screwy - need advice please.
  • 1 Vote(s) - 5 Average
omarztaco
10-31-2012, 12:47 PM #1
Hey guys,
I've searched here, peach parts and benzworld for some advice or tech about what my next step is. Here's what happened-and before you flame me let me just say that i understand I fucked up and adjusted something I shouldn't have.
I turned my full load up, then matched it with the high idle. I was sure I turned the right screw but I was wrong. Instead, I adjusted the torque control screw. Ever since I cannot get her to run right. I've played with adjusting it and I made some progress getting it back to where it was before I started messing with it. I've made progress on tuning the pump all together but she just doesn't run right. I know nobody can tell me exacltey what to turn or adjust but I need some guidance on what to do next.
Symptons - Dead cuts off at 2000rpm. she will not rev any higher under a load than that. Unloaded, everything seems fine (which doesn't really matter). The car never did make it up a hill when I first got it. I've done all the routine maintenance to assure nothing is holding it back, removed egr etc and still she falls flat on her face. Later today I will make a video and upload so you can see and hear it if that will help.
Any ideas or should I just keeping tweaking everything until I find the "sweet spot" ?
This post was last modified: 10-31-2012, 12:58 PM by omarztaco.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
Hey guys,
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
OM616
10mm MW
572
10-31-2012, 12:59 PM #2
(10-31-2012, 12:47 PM)omarztaco Hey guys,
First off...STOP!!! Do not do anything until you understand what you are doing. The good news is that you are not the first to find himself in this situation.
What are you using as a technical reference to identify the adjustment screws?
OM616
omarztaco
10-31-2012, 01:08 PM #3
I can find all sorts of things out about the MW pump but not so much for the M pump. I planned everything out and studied before i proceded but I still managed to screw it up.
(10-31-2012, 12:59 PM)OM616
I have the Ip adjustment material from this site.
This post was last modified: 10-31-2012, 01:30 PM by omarztaco.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
10-31-2012, 02:54 PM #4
here is a video clip if this helps.
http://www.youtube.com/watch?v=H4wThrHdlcU&feature=plcp
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
OM616
10mm MW
572
10-31-2012, 10:10 PM #5
I bet you backed off the High (Max) Speed Adjustment instead of the Idle based on the video.
It is obviously putting out fuel until it hits the cut off speed that it is now adjusted to.
I do not have time right now to look in the manual to see (confirm) which screw is the High Speed adjustment on the RSF Governor.
If you are confident that you know which is the High Speed, Give it a 3 or 4 turns in and see if the engine revs higher.
OM616
omarztaco
11-01-2012, 05:25 AM #6
Thank you! I feel better with a second opinion. Ill give it a few turns and see how it does. I was confident to think it was my torque control but didnt want to go any further.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
Siekkinen
11-01-2012, 08:59 AM #7
Did you adjust the screw with an allen head or that screw which has a 22mm (can't say what it is in inches) lock nut and can be turned by fingers? The allen head screw is the max rpm screw and one turn makes 300 in rpm's. The screw with a lock nut is a torque capsule and it cuts max fuel at some rpm but it doesn't totally cut rpm's. The screw at lower left with a 10mm lock nut is the full load and the screw at upper right which is similiar to full load is the idle screw.
Do you have any idea how many turns did you adjust the max rpm?
w124 300 STD/daily driver
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
OM616
10mm MW
572
11-01-2012, 10:03 AM #8
(11-01-2012, 08:59 AM)Siekkinen Did you adjust the screw with an allen head or that screw which has a 22mm (can't say what it is in inches) lock nut and can be turned by fingers? The allen head screw is the max rpm screw and one turn makes 300 in rpm's. The screw with a lock nut is a torque capsule and it cuts max fuel at some rpm but it doesn't totally cut rpm's. The screw at lower left with a 10mm lock nut is the full load and the screw at upper right which is similiar to full load is the idle screw.
After thinking about it, he would have had to back off the Max speed a bunch of turns to get it to limit to 2K RPM, Same for the Torque Control, but the Torque Control is more responsive shall we say, so Perhaps he did back off the Torque Control way too far as he thought. The fuel is definitely being regulated.
Be sure that the ALDA is working properly too.
If tweaking the Max Speed doesn’t do it, put it back and turn up the Torque Control and see if it raises the RPM under load. Keep a log of every adjustment so you can get back if you need to.
OM616
omarztaco
11-01-2012, 11:07 AM #9
I never touched the Allen head one. Only the 2m lock but that turns freely which I'm sure is the torque control.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
Siekkinen
11-01-2012, 12:07 PM #10
(11-01-2012, 11:07 AM)omarztaco I never touched the Allen head one. Only the 2m lock but that turns freely which I'm sure is the torque control.
Then it really is the torque control. Adjust it clockwise two turns and try. If it helps, adjust half turn clockwise until rpm's don't get back to idle and then 1/4-1/2 turn back counter clockwise. Go to a test drive and make sure that rpm's get back to idle also when the engine is warm.
That really is a screw which shouldn't be touched if you really don't know what to do Big Grin
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
omarztaco
11-01-2012, 01:15 PM #11
Thanks guys. Getting ready to adjust it and try it out. I've never messed with Mercedes diesels. I grew up to them from my patents but when I was old enough to start working on them, we had all gas Mercedes. This is a learning curve from hell but its worth it.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
Siekkinen
11-01-2012, 01:31 PM #12
(11-01-2012, 01:15 PM)omarztaco Thanks guys. Getting ready to adjust it and try it out. I've never messed with Mercedes diesels. I grew up to them from my patents but when I was old enough to start working on them, we had all gas Mercedes. This is a learning curve from hell but its worth it.
It's really worth of learning. Diesel Mercs really are good cars especially when you get some power out of them Big Grin I have learned over the years that they really need a lot of repairing but it's worth it.
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
omarztaco
11-01-2012, 10:54 PM #13
Update - after slowly adjusting the torque control half turn by half turn it took 5 and half whole turns clockwise. 6 clockwise turns made her "runaway". I cranked it back a half a turn and she didn't runaway. Took it for a drive each time I adjusted it a half turn. She still cut off at 2k. I noticed my tranny linkage was unhooked. Does that affect this? I thought that was just a kick down linkage? I hooked it back up and it ran better but in no way is it still right.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
Siekkinen
11-02-2012, 11:11 AM #14
(11-01-2012, 10:54 PM)omarztaco Update - after slowly adjusting the torque control half turn by half turn it took 5 and half whole turns clockwise. 6 clockwise turns made her "runaway". I cranked it back a half a turn and she didn't runaway. Took it for a drive each time I adjusted it a half turn. She still cut off at 2k. I noticed my tranny linkage was unhooked. Does that affect this? I thought that was just a kick down linkage? I hooked it back up and it ran better but in no way is it still right.
That linkage doesn't matter. Try to adjust the allen head screw one turn clockwise only for a sure. If it now revs higher, that's it Big Grin
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
OM616
10mm MW
572
11-02-2012, 12:13 PM #15
When were you going to tell us that the trans was not right???
Have you put the shifter in low (so it will not shift automatically) and tried to run it up? The Converter stall speed is right about 2K RPM I bet... The trans could be shifting way too soon, or is jumping from 1st to third for example, these engine do not have any torque at the low end so it would fall flat to the stall RPM.
That would explain why you have boost while it is stuck @ 2K. If the fueling was being cut, the boost would fall off as well. I am leaning toward a trans problem.
OM616
Siekkinen
11-02-2012, 12:25 PM #16
But it isn't working although the linkage is hooked.
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
omarztaco
11-02-2012, 04:01 PM #17
I just noticed that linkage unhooked yesterday. I haven't had a tranny problems that I know of? I just realized yesterday that she is shifting from 1st to 4th.
After searching old threads for symptoms like mine, I'm going to check the lockdown switch and check any un hooked vacuum lines. It's been so long that I can't remember what it drove like when I got it. I will rule out all the simple things before I turn to you guys again. I thought it was fuel related which it probably had some affect but now I don't know. Thank you guys for helping. I'll tinker with it today and see what I dig up.
This post was last modified: 11-02-2012, 04:48 PM by omarztaco.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
11-02-2012, 05:05 PM #18
Ok after checking vacuum lines, I found this tucked under my IP. It connects to a blue thing on the strut tower. No clue what it is or what it does. The picture is crappy I know but there is a screw plug into the end of two vacuum lines.
http://m1296.photobucket.com/albums/omar...eEd8LSg%3D
This post was last modified: 11-02-2012, 05:06 PM by omarztaco.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
aaa
11-02-2012, 05:21 PM #19
The blue thing helps control shift stiffness along with the valve it's connected to on the pump. It's not a vacuum issue.
Try removing the ALDA, it should've been the first step before opening the back of the pump.
aaa
omarztaco
11-02-2012, 05:31 PM #20
Alda is removed. I did that before adjusting the pump.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
aaa
11-02-2012, 05:55 PM #21
I still feel like something simple like fuel or air/exhaust restriction may be the issue, if it wasn't performing right to begin with.
aaa
omarztaco
11-02-2012, 06:01 PM #22
After looking at everything, you're probably right. I think I'm thinking too much into it. It has to be something simple.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
OM616
10mm MW
572
11-02-2012, 08:24 PM #23
(11-02-2012, 04:01 PM)omarztaco I just noticed that linkage unhooked yesterday. I haven't had a tranny problems that I know of? I just realized yesterday that she is shifting from 1st to 4th.
That would do what the video shows. If you can keep it from shifting out of first, I bet it will go like hell with the pump adjusted like it is, lol.
Fix the trans and you will be happy.
OM616
omarztaco
11-02-2012, 09:45 PM #24
Update- hooked the "Bowden cable back up and I've been adjusting it. Running a 100x better. She's holding each gear and revving good. Still more tweaking to get it right but its night and day difference. Question, would it be a good idea to adjust my torque control back to where It was. Since that obviously didn't change what it was doing.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
11-03-2012, 02:59 AM #25
I've been tinkering with the bowden cable and now 1st climbs to 3500rpm's before shifting into second. From 2nd gear on it is very doggish and still has a "cut off feel" to it. it is revving a little higher now but still no luck. I'm literally searching all forums but I cannot come up with a solution. I changed tranny fluid and filter last week, Fuel filter etc. Full open 3" exhaust from turbo back, removed EGR, vaccum lines, ALDA removed etc. There is a place in Columbus Ohio that does heavy diesel work for pulling trucks and such. Maybe I should take it to them? I opened up a can of worms by messing with the wrongs adjustments in the IP and I'm paying the price but now I'm at my limit. I wish you guys were closer and could have you pysically look at this car.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
Siekkinen
11-03-2012, 07:49 AM #26
That torque control adjust which you did isn't dangerous so you can keep it that way. How high does your engine rev when you put your gearstick to "2-gear" position (I don't know word for it)? It should rev up to ~4700-5000 rpm.
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
OM616
10mm MW
572
11-03-2012, 12:07 PM #27
You should be able to shift it manually. That trans has problems and it would appear that someone started disconnecting everything to remove it.
There is a governor in the trans that may have an issue, Regardless, the trans needs to be diagnosed and repaired, or swapped out. It is still shifting out of sequence.
OM616
Siekkinen
11-03-2012, 06:16 PM #28
Oh, I thought that it shifts at 3500 at full throttle. If it does that on normal acceleration it's really shifting too late. Your kick down cable is too tight then. You can loosen it from the adjust which is behind the ip.
But then again problem could be a faulty tranny. It's just weird if everything worked fine before you begin to adjust the ip.
w202 250 TDT
w201 2.6E
Siekkinen
w202 250 TDT
w201 2.6E
omarztaco
11-03-2012, 06:50 PM #29
Here is another video after tinkering with the bowden cable.
http://www.youtube.com/watch?v=lwy3zrs5m20&feature=plcp
(11-03-2012, 12:07 PM)OM616 You should be able to shift it manually. That trans has problems and it would appear that someone started disconnecting everything to remove it.
Could very well be my tranny. I have a tranny from a w124 300e i could try if it is the same? The guy I got it from did not know anything about a mercedes let alone a diesel.
This post was last modified: 11-03-2012, 06:52 PM by omarztaco.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
OM616
10mm MW
572
11-04-2012, 12:02 AM #30
Is the throttle linkage adjusted properly so the IP is seeing full throttle? My understanding of the RSF Governor is when you do a full load (rack Limiter) adjustment, you also have to adjust the throttle linkage.
The engine does not sound like it is trying to build power at all.
HOLD ON A SECOND!!! EDIT:
I was in the shower reviewing the information in this thread in my head and realized something. If it is true that the car ran normally prior to any governor adjustments, (hard to believe because the trans was not hooked up properly), then I have a question, WHICH WAY DID YOU TURN THE FULL LOAD SCREW??? Did you turn it in, or out?
The videos have been very helpful as I can hear what the engine sounds like, and at 3K RPM, it should be making power enough to hear it working its ass off to be held at 3K, but if you had not said that you had it floored, I would have thought you were barely pressing on the pedal.
I bet you turned the full load screw the wrong way and actually reduced the fueling capability instead of increasing it. Which way did you turn it????
I have not played with the RSF Governor, but have a lot of experience with the RW Governor used on MW pumps. From what I have read on the RSF Governor, you back out the full load screw, as in turn it CCW to increase fueling, if you turned it in, (CW), then you reduced the fueling.
This post was last modified: 11-04-2012, 01:58 AM by OM616.
OM616
omarztaco
11-04-2012, 05:46 PM #31
(11-04-2012, 12:02 AM)OM616 Is the throttle linkage adjusted properly so the IP is seeing full throttle? My understanding of the RSF Governor is when you do a full load (rack Limiter) adjustment, you also have to adjust the throttle linkage.
Yes I turned it CCW until its basically touching the back plate. Thanks you for all your help! Here is my new situation lol, After tweaking the bowden cable and the torque control, She will almost break tires in 1st and 2nd in both scenarios- manually shifting or leaving it in D. After 2nd she falls flat again. But it is a little better. She revs to about 3500-3800 in 1st and 2nd. After 2nd she struggles to get to 2k even at WOT. I havent been able to get the car over 40mph no matter what gear or throttle positon. I want to rule one or the other. Does this sound like anything you have heard before? I will make another video of how it runs now.
Yes the throttle linkage is adjusted. The Ip can go wide open.
This post was last modified: 11-04-2012, 05:53 PM by omarztaco.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
OM616
10mm MW
572
11-04-2012, 06:13 PM #32
You really need to plead with Dieselmeken to help you. I have not played with the RSF Governor, and there are a lot of things that are not right on your car. We are all spinning our wheals with this, there is just too much wrong to diagnose remotely. I recommend selling the car, or taking it to a MB shop, they will pull the pump and send it out to be recalibrated and they can address the trans problems.
[/b]
OM616
[/b]
omarztaco
11-04-2012, 06:39 PM #33
I was hoping it would not come down to that. Thank OM616 for all your help! I have a basketcase on my hands but I'm determined to over come this. This car is my "Elanor" from Gone in sixty seconds. My parents bought one of these in 96 with 48k on it. Around a 80k I filled it with gasoline at a pump one day. Then, around 100k, the crank went out. Then, about 2k after the new motor my dad crahed the car and almost died. It has been a cursed car from my childhood and now is proving to be the same thing again. I will continue to mess with it until I give up and send her to MB. If any new breakthroughs occur I will update you.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
aaa
11-04-2012, 08:01 PM #34
You could swap another pump on. Although timing isn't fun.
aaa
omarztaco
11-04-2012, 08:37 PM #35
(11-04-2012, 08:01 PM)aaa You could swap another pump on. Although timing isn't fun.
I thought about that too! Prices around here are just as much as buying a whole car. I'm on the hunt for a spare 2.5.
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
omarztaco
03 ML320
00 SLK230
98 C230
94 C220
91 300D 2.5
86 300E
72 300SEL 4.5
