STD Tuning Engine OM606 how to get 250-300hp
Davo
11-21-2012, 07:17 AM #1
Hi all,
I'm obviously new here. I've had a few mercs in my life, but this is my first diesel.
I haven't bought a car yet, but I'm deciding between either a W124 OM603 non-turbo and a W210 OM606 turbo. These are the only diesel models we got in Australia for their respective series.
Anyhow, first off which would you suggest is the better more reliable model?
What sort of fuel consumption are you guys getting out of your OM603/606T?
What mods do I need to do to get the OM606 up to 250-300hp? Without effecting fuel consumption too greatly.
Is it hard to turbo a OM603?
I look forward to your help.
Davo
Hi all,
11-21-2012, 07:43 AM #2
I think that if $ is of little influence then, the 606 is the obvious choice.
A turbo motor is better than a non turbo for example.
Davo
11-21-2012, 08:40 AM #3
That's what I was thinking... W124 300D here in Aust are only slightly cheaper then a W210 E300DT anyway! It was more the issues related to the rest if the W210 that bothered me.
As stated by Jack Baruth, writer for The Truth About Cars, "Mercedes-Benz should formally apologize for the W220 and W210. Every customer who purchased a new S-Class or E-Class from those infamously troubled generations should receive a letter in the mail, hand-signed by Dr. Panzer Kampf-Wagen or whoever is running the show nowadays, apologizing for selling them an utter piece of junk. Hundreds of thousands of customers were basically swindled. They thought they were buying a Mercedes-Benz, not a cost-cut half-plastic embarrassment. Make it right. And throw them a little incentive towards the price of a new (and presumably better) Benz, just to make up for the abysmal resale on, say, the 2001 S430."
Davo
erling66
SuperDieselVan
294
11-21-2012, 10:59 AM #4
My choice would be to buy the W124 and put a 606 turbo in it. Then you will have the best body and the best engine without to much hassle from the electronics.
HuhCoolTongue
erling66
HuhCoolTongue
Davo
11-21-2012, 07:40 PM #5
That'd be nice! I don't have the time or the workshop for that though..
Davo
majesty78
11-22-2012, 01:43 PM #6
Remember in W210 300TD the 5spd A/T is only rated up to 370Nm from stock.
So building a engine with reasonably more power will in most situations also have way more torque, more than this gearbox in stock conditions can handle.
This was the reason I decided against the OM606 in W210 and went for the CDI which has stronger gearbox...
BR
Alex
majesty78
BR
Alex
Davo
11-22-2012, 08:11 PM #7
Ahhhh ok, I didn't know that!
We don't get the 320 CDi here in Aust though, only the 270. Did they have the stronger 'box also?
Davo
Davo
11-23-2012, 11:56 PM #8
Bump!
Davo
Bump!
majesty78
11-25-2012, 02:11 PM #9
IIRC 270CDI has same gearbox but slightly different ratio of rear differential.
majesty78
hooblah
11-25-2012, 05:41 PM #10
What manual gearbox would you attach to a 606 running 300bhp? I was thinking w201 2.5 cosworth box? Anything else I could use?
hooblah
majesty78
11-26-2012, 03:01 AM #11
http://www.superturbodiesel.com/std/thread-3146.html
220CDI 6spd seems to work fine :-)
majesty78
