STD Other Projects 300CE Turbodiesel
300CE Turbodiesel
300CE Turbodiesel
  • 4 Vote(s) - 4 Average
pena837
11-22-2012, 03:02 PM #1
i'm rebuilding 300ce -88.
Almost all of the bodywork is done, some little rust fixing still to do and paint job.
[Image: _img900.jpg]
Bilstein Sprint B8 shocks and H&R -30mm springs
Motor is going to be original om606 turbo with little changes.
exhaust manifold
Holset HX55 turbo and 60mm wastegate
4'' Downpipe and rest of the pipe is going to be 3,5'' with one vibrant resonator
intake manifold and 8mm herlevi pump.
All aluminium Griffin radiator and cooler
Cool
pena837
exhaust manifold
Cool
EDH_Performance
11-22-2012, 04:18 PM #2
Cool project!! But why go with a such a big turbo, takes ages to get it to spool....?? Or are you building a 700hp engine?
EDH_Performance
pena837
11-22-2012, 11:47 PM #3
to get high hp . We will see how it spools, exhaust housing is not that huge in this turbo, as usual in these sizes, so hopefully it works good . of course it depends how my exhaust manifold etc. works
pena837
erling66
SuperDieselVan
294
11-24-2012, 12:48 PM #4
Very nice projectSmile Is the turbo exhaust house 16cm2?
Will it pass inspection with diesel engine in Finland?
Please keep us updated with more photos
HuhCoolTongue
erling66
HuhCoolTongue
pena837
11-24-2012, 01:46 PM #5
(11-24-2012, 12:48 PM)erling66 Very nice projectSmile Is the turbo exhaust house 16cm2?
yes it is 16. inspection is not a problem, i just need to have dyno evidence that it doesn't have more than 180hp so i it will pass the inspection with 300e original brakes etc.
pena837
pena837
11-27-2012, 02:37 AM #6
couple hours in garage yesterday and boost pipes are ready
pena837
Bangaway
606 Turbo > Porsche Turbo
129
12-02-2012, 02:56 PM #7
What model is that Griffin radiator and cooler?
Bangaway
Ksteen2
12-03-2012, 05:29 AM #8
Niiice Wink
I'll watch this closely, hope it works smack Wink
If only we could pass inspetions i here in norway with those specs..
to hell with the pottato norwegian state..
had been so easy Wink
Ksteen2
Niiice Wink
pena837
12-07-2012, 02:28 PM #9
(12-02-2012, 02:56 PM)BigAssCFotPrint What model is that Griffin radiator and cooler?
i dont remember the model, called one dealer here in finland and ordered radiator that fits mb w124 Big Grin somekind DIY, you have to make brackets yourself. and cooler in 450x300 china cooler.
pena837
Bangaway
129
01-15-2013, 06:58 PM #10
Any updates with the project?
Bangaway
pena837
01-22-2013, 02:34 AM #11
no, snowmobile season slows this project in wintertime.
pena837
mantahead
01-22-2013, 07:50 AM #12
hi,
nice project, what size of piping did you use on your exhaust manifold?
mantahead
hi,
pena837
01-25-2013, 02:43 PM #13
42mm/38mm
pena837
42mm/38mm
01-25-2013, 11:18 PM #14
Great build! Thank you for sharing the intercooler details.
pena837
10-22-2013, 03:02 AM #15
low boost testing,
http://www.youtube.com/watch?v=vcJGlZb3Q...e=youtu.be
mantahead
10-22-2013, 03:21 PM #16
sounds awesome, what do you call low boost?Big Grin
mantahead
pena837
10-22-2013, 03:24 PM #17
2,5bar
pena837
2,5bar
mantahead
10-22-2013, 04:08 PM #18
Big GrinBig GrinBig Grin
mantahead
Tito
10-23-2013, 01:06 AM #19
after hearing that it sucks that i can't see any pictures Undecided
This post was last modified: 10-23-2013, 01:06 AM by Tito.
Tito
pena837
10-23-2013, 01:34 AM #20
http://pena837.kuvat.fi/
there you can find almost all the project pics
pena837
10-23-2013, 08:19 AM #21
I couldn't hardly see from the pics, but how does your wastegate bleed off all cylinders with your custom header?
EDH_Performance
10-23-2013, 08:27 AM #22
(10-23-2013, 08:19 AM)MFSuper90 I couldn't hardly see from the pics, but how does your wastegate bleed off all cylinders with your custom header?
I saw that too...Not all sylinders goes trough the wg, only cyl 3 and 4!
Pressure drops but not all gasses will be wastegated^^
But it seems like it works, but not idealSmile
Sometimes you must comprimise due to tight spaceBig Grin
EDH_Performance
Ksteen2
10-24-2013, 02:55 AM #23
it drains all the cylinder, mabye not in he best way, but its a twin scroll flange, and waste gated from each side, so it should not be a problem ;p
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
1#
Originaly a d24tic
6speed cdi box
pena837
02-18-2014, 04:47 AM #24
New intake manifold and boost pipes upgraded to 3''
[Image: _smaller.jpg]
pena837
maxypriest
02-18-2014, 07:14 AM #25
a work of art
maxypriest
a work of art
02-18-2014, 05:40 PM #26
nice!
nice!
pena837
08-31-2014, 04:34 AM #27
new intake manifold worked good, so good that we found the limits of original rods Big Grin
all rods are bend more or less, and 3rd let go for good, in 4th gear, full gas about 180-200km/h, quite a big bang Big Grin, still drove it to the garage with 5 cylinders.
Well, new engine is in the garage, lets make it stronger for next summer Wink
pena837
mario
08-31-2014, 05:20 AM #28
Well if she drove to the garage she is some little trooper as what are the plans now
mario
pena837
08-31-2014, 10:50 AM #29
still thinking what to do, maybe smaller turbo and make it more ''daily driver'' but that would be little boring?? Big Grin
second option is , stronger rods, good main bearing ''girdle'' in bottom end, maybe update cylinder head more, and enjoy some serious power Big Grin but this option in going to be €€€€€€ so we will see..
This post was last modified: 08-31-2014, 10:51 AM by pena837.
pena837
Keino
08-31-2014, 12:49 PM #30
@ how much boost pressure were you driving it after installing new intake manifold? Tongue
Keino
pena837
08-31-2014, 01:32 PM #31
Only about 2,5bar. I believe the rods bended at earlier tests when boost pressure got up to about 3,5bar (and 7000rpm) After 300km of test with those settings cold starts started to sound bad. When the engine warmed up to normal it did run good and no problems. Then few hundred km more this happened
pena837
09-01-2014, 07:29 AM #32
Awesome, very well doccumented. and Very skilled fabrication work!
sorin_cel
71
09-21-2014, 09:22 AM #33
if the rod got bented, and cylinder block smashed in half, that means it was some SERIOUS POWER over there.i'm curious to know if the 3,5bar boost caused that...Confused
sorin_cel
pena837
09-27-2014, 01:36 PM #34
I dont think boost alone will make that happen. But HX55's airflow in 3,5bars + 7000rpm + alot of fuel all together can make little too much stress for original rods. Or maybe the earlier head gasket failure had something to do with this but i dont think so, gasket leaked only ''outside'' , when boost pressure raised up, gasket leaked it to cooling system and overpressured it so that radiator cap opened and coolant got out. Atleast i didnt find any signs of coolant in the cylinders when i pulled the head off...
pena837
09-30-2014, 06:50 AM #35
It's usually revs that overstresses reciprocating parts.
Looks like the conrod let go of the gudgeon pin while trying to decelerate the piston towards TDC..
mantahead
09-30-2014, 04:48 PM #36
she went with a bangCool
did the crank survive?
what make are the head studs?
mantahead
pena837
10-01-2014, 01:17 AM #37
rod did made little marks in the cranks ''weights'' as you see in the picture.
Head studs are from akracing.fi
pena837
mantahead
10-04-2014, 02:36 PM #38
hi,
what sort of power do you think you had??
was it high rpm that pulled the small end bearings apart and killed the engine?
mantahead
hi,
