STD Tuning Engine Where to buy racing plenum?
m2rkz
11-24-2012, 04:28 AM #1
Where to buy racing intake plenum in Europe? I want to combinate it with om606 original intake manifold. Price must be very good.
This post was last modified: 11-24-2012, 04:28 AM by m2rkz.
m2rkz
maKe-
11-24-2012, 10:43 AM #2
I think you are referring to this? (New to the site! Hi!)
[Image: 805fe495c017f761954506a0c4303aef.jpg]
[Image: 56244983b75390f8d2c07381713dcca8.jpg]
[Image: ec666f8c3922d0037fd40daaaad8fb84.jpg]
[Image: c06cf5ff6dd781562951a44e164cc022.jpg]
[Image: bee2ba0d72d7ab5d128d20dddce5a2c0.jpg]
[Image: c8bd02179791f3cfd1365d927069002e.jpg]
[Image: efa2b51f845a2cc9cf29fe24a6ae59e5.jpg]
Price 255€ for 6cyl plenum diy kit and 20€ for each velocity stack if needed.
From Finland @ AMW dyno service. Email: juha.martikainen at amwdynoservice.com
maKe-
Booster
11-25-2012, 11:57 AM #3
Do you make a fully welded one for a om605? Bolt on?
Booster
Turbo
11-25-2012, 04:06 PM #4
Do you know if you can do custom order in different layout?
At what rpm is it maximum tune regarding volumetric efficiency
how much boost can it handle?
This post was last modified: 11-25-2012, 04:39 PM by Turbo.
Turbo
maKe-
11-26-2012, 03:46 AM #5
Don't ask such hard questions from me, ask the owner of the company. Big Grin
He speaks English so it's not a problem if you can't make it in Finnish.
Boost wise it should hold anything depending how good it is welded, and (maybe) reinforced at some points. The plenum case halves are made of 4mm pressed alu sheets and the tapered tube is 3mm bended alu sheet.
Volumetric efficiency etc. is a good question, but the answer for it does not come from me. What I understand is that this is mainly universal plenum kit for 4-6cyl motors that "should" work better than OEM and make charge pipe routing alot more flow friendly than most OEM intakes. The tapered tube design seems quite good and should make close to equal flow and volume between first and last runner, because it tapers down near the last runners.
Also the intake design looks quite alot like in WRC cars...if that is a good thing or no, I don't know. Big Grin
[Image: DSC03720.JPG]
maKe-
11-26-2012, 09:59 AM #6
$20 for velocity stacks is cheap Big Grin
Turbo
11-26-2012, 04:05 PM #7
I have e mail the owner, interesting to see what he respond
(11-26-2012, 03:46 AM)maKe- Don't ask such hard questions from me, ask the owner of the company. Big Grin
Turbo
300SD81
11-26-2012, 08:35 PM #8
Is there a benefit to it choking down to such a small opening rather than having the boost hose connect to the large section?
Ich liebe meine Autos!
300SD81
Mark_M
11-27-2012, 12:58 PM #9
(11-26-2012, 08:35 PM)300SD81 Is there a benefit to it choking down to such a small opening rather than having the boost hose connect to the large section?
the idea is that the air velocity is the same at all ports. At the start you have all cylinders drawing air but at the back you have only one. Most performance plenums taper down to the furthest cylinder or cylinders if its a centre feed.
Mark_M
Turbo
12-11-2012, 04:46 PM #10
Can be a good company but still no answer, so by now I guess hell will freeze to ice before I get some feed back from my e mail to them ...
somebody here have there phone number and fax number?
Turbo
SurfRodder
Jackass Extraordinaire
611
12-14-2012, 10:27 AM #11
(12-11-2012, 04:46 PM)Turbo somebody here have there phone number and fax number?
from their website;
http://amwdynoservice.com/page19.php
Yhteystiedot
AMW Dyno Service Ay
Juha ja Heli Martikainen
Vihtolantie 37
53650 Lappeenranta
Finland
juha.martikainen@amwdynoservice.com
www.amwdynoservice.com
puh +358 500 759 612
fax +358 5 411 8717
OBK# 62
SurfRodder
from their website;
Yhteystiedot
AMW Dyno Service Ay
Vihtolantie 37
53650 Lappeenranta
Finland
fax +358 5 411 8717
OBK# 62
