w210 diff change.
w210 diff change.
diff question for you guys!
i`m planning to change the diff in my w210 e230 (om606-converted).
it has a 3,46 ratio ,and im trying get a hold of something lower.2,65/2,88.does anyone know if a w124 diff will fit in this car?
the 3,46 diff measures 22cm between the driveshaft flanges..
(11-24-2012, 09:28 AM)w210tdt diff question for you guys!
(11-24-2012, 01:05 PM)EDH_Performance(11-24-2012, 09:28 AM)w210tdt diff question for you guys!
I do not think it will be bolt on! The 210mm is very bigHave one with 2,2 ratio
Planning to use in my 190d superturbo project
(11-24-2012, 01:35 PM)w210tdtI think you can get it with high ratios as well(11-24-2012, 01:05 PM)EDH_Performance(11-24-2012, 09:28 AM)w210tdt diff question for you guys!
So the 210mm diffs Are the ones with low gear ratio?and my 3,46 is 185mm then?
2,20 sounds Nice ,planning to go 300km/h in your 190?
