STD Tuning Drivetrain w124 2.5D turbo diff selection?
Falkrum
12-05-2012, 02:59 AM #1
Hello guys, can you help me to select best diff ratio for my car. In stock w124 2.5D turbo with automatic has 2.65 ratio. Right now i use 3.07 ASD diff from 300E. I need to change that diff because it is very noisy - dead gears.
In fact i dont need high max speed. I want to get fast acceleration, but with low fuel consumption.
What will be if i get 3.46 diff? I know the acceleration will be better but the RPM is also will be higher. So how it will affect fuel consumption?
Falkrum
aaa
12-06-2012, 01:29 AM #2
Depends on how fast you go. If you do 70mph all the time then 3.46 is sure to affect it by a couple mpg.
aaa
