STD Tuning Engine hi flow air cleaner
hi flow air cleaner
hi flow air cleaner
Jtn190D
MERCEDES DIESEL POWER!
192
06-09-2009, 07:03 PM #1
Hi all im new here. I have 87 190D 2.5 turbo i wanted to now if i can change my stock air cleaner to a hi flow one.[/size]
Jtn190D
06-10-2009, 07:51 AM #2
You already got the best air filter box in there already. You just need to tune other items to get more performance out of your engine.
630CFM is damn good for a stock box. Anything else (i.e. K&N Filter) would actually restrict flow.
From the WIX Filter Website.
Part Number: 42228
UPC Number: 765809422285
Principal Application: Mercedes 190D Turbo (87), 350SD, 350SDL Turbo (90-91), 300 Series (86-87)
All Applications
Style: Air Filter
Service: Air
Height: 5.135
Outer Diameter Top: 11.135
Outer Diameter Bottom: 7.700
Inner Diameter Top: 6.995
Inner Diameter Bottom: 3.560
Ends: Plastic
Oval Shape: Yes
CFM: 630
Part Number: 42228
All Applications
Style: Air Filter
Service: Air
Height: 5.135
Ends: Plastic
Oval Shape: Yes
CFM: 630
SurfRodder
Jackass Extraordinaire
611
06-10-2009, 09:27 AM #3
I'd be willing to bet the K&N will outflow the stocker, probably by at least 100cfm, but it wont provide any more *usuable* flow for an engine that is not fairly-well modified... They also do not filter as well as the stock unit, a lot of offroaders don't use 'em anymore after finding silt in their intakes.
The only real advantage with a k&n stock replacement is the reusable aspect of it, but I'd still rather go paper filter to ensure no dirt gets into my intake...
OBK# 62
SurfRodder
OBK# 62
06-10-2009, 10:48 AM #4
(06-10-2009, 09:27 AM)SurfRodder I'd be willing to bet the K&N will outflow the stocker, probably by at least 100cfm, but it wont provide any more *usuable* flow for an engine that is not fairly-well modified... They also do not filter as well as the stock unit, a lot of offroaders don't use 'em anymore after finding silt in their intakes.
I was referring to the common K&N cone type filter like the setup you find on eBay. If K&N made a filter specifically to this box, then yes it will probably flow better with the drawback of not filtering as well. .
Jtn190D
192
06-10-2009, 11:11 AM #5
Is it normal not to hear the turbo at all?
Jtn190D
SurfRodder
611
06-11-2009, 12:21 AM #6
(06-10-2009, 11:11 AM)Jtn190D Is it normal not to hear the turbo at all?
yeah, with the stock unit you wont hear much..especially with how loud the rest of the engine is...
OBK# 62
SurfRodder
OBK# 62
06-11-2009, 05:20 AM #7
A K&N will flow more air at the expense of having a much shorter engine lifespan.
Look here to see what K&Ns suck so bad: http://duramax-diesel.com/spicer/index.htm
The best filter is what you have already. Its flows more than your engine needs, it filters very well, its a true cold air intake, the filter is cheap and its extremely easy to maintain.
This post was last modified: 06-11-2009, 05:20 AM by ForcedInduction.
