STD Tuning Engine dual pump
dual pump
dual pump
bricktron
'77 240D
174
12-07-2012, 02:56 AM #1
it would require some seriously creative fitment, but has anyone tried hooking up two 617 injection pumps in parallel?
two round 5.5mm openings are a bit bigger than a single 7.5mm one.
ready to hear that i am crazy.
thanks,
aaron.
This post was last modified: 12-07-2012, 03:00 AM by bricktron.
bricktron
thanks,
aaron.
dieselmeken
12-07-2012, 04:12 AM #2
(12-07-2012, 02:56 AM)bricktron it would require some seriously creative fitment, but has anyone tried hooking up two 617 injection pumps in parallel?
thanks,
aaron.
Whats the purpose? And yes, thats crazy.
Its not all about the size,5,5+5,5=11 vs 7,5 Its much moore, duration on element etc etc.
However, i did see a clip on youtube 6,2L Chevy V8 diesel with 2 Stanadyne DB2 pumps side by side.
dieselmeken
thanks,
aaron.
DirtDiesel
12-07-2012, 12:05 PM #3
i know they do it for the cummins thats as far as i know about it
LiL Micky
DirtDiesel
LiL Micky
12-07-2012, 12:06 PM #4
It could be done with a modified block by driving the second IP from a second chain hooked to the vacuum pump sprocket. Timing it accurately would be insane.
mantahead
12-07-2012, 06:45 PM #5
hi,
i had thought of this before also but timing both pumps would need to be spot on.
mantahead
hi,
dude99
12-07-2012, 07:34 PM #6
Perhaps you could put a shaft where the ip originally sat and have it extend out of the morot. Then you could drive both pumps of the shaft.
dude99
Volker407
naturally aspirated
157
12-08-2012, 12:21 PM #7
What engine are you talking about? If OM617A then you can go up to 10mm elements with one pump and that will be far enough to drown any OM617A I have seen until now.
Gruß
Volker
Volker407
Gruß
Volker
OM616
10mm MW
572
12-08-2012, 12:48 PM #8
(12-08-2012, 12:21 PM)Volker407 What engine are you talking about? If OM617A then you can go up to 10mm elements with one pump and that will be far enough to drown any OM617A I have seen until now.
Gruß
Volker
LOL...There are 12mm elements that can be had, but they require heavy mods to the pump housing. I mean if the goal is to go crazy..... Big Grin
OM616
Gruß
Volker
bricktron
'77 240D
174
12-08-2012, 01:45 PM #9
yes Volker, just curious about solutions that do not involve sending thousands of euros to Finland Smile
Gruß
Volker
bricktron
Gruß
Volker
