Parting out 83 300D & 79 300SD
Like the title says. Most of the interior panels are all there seats are all still good in both. Both have the light tan colored interior. 83 has no engine or trans. 79 (w116) has engine and trans. engine has aweful rod knock but still drove to where it sits now.
Just let me know what parts you may be interested in and I will get pics and prices for you. Cars are located in baxley ga. They are at my dads shop about an hour away from my house but I'm down there every weekend. Just thought I would post them here and see if someone could use some parts b4 we sent them to the scrap yard.
I might be interested in some of the SD parts, I have been searching for a while for stuff. I'm looking for pretty much anything electronic located in the dash (minus the instrument cluster) so climate control unit I think will be the big one, also headlight switch, as well as rear seat both top and bottom.
The guy I bought my project car from left it outside in the mountains uncovered with bad seals on the front and back windshields, so a bunch of interior stuff is all crappy
Will check this weekend. I only get down there on sat and sundays.
Will check out the 79 w116 for the climate clontrol and headlight switch. I know they are there just unsure the shape. the back seats would be pretty expensive to ship to fresno though. I will do it, just up to you.
Check the w123 for the rear bumpstop.
Do you have the non-EGR manifolds?
Alright, sounds good. Yeah my interior is dark blue so the light tan might not work with that too well, but I'm fairly certain I'll be needing a new climate control unit and headlight switch, since neither appear to be working properly.
Is the SD turbo? if not, what does the intake look like? Probably intirested
(12-09-2012, 08:53 PM)jandamerc Like the title says... 79 (w116) has engine and trans. engine has aweful rod knock but still drove to where it sits now.
update.
The bumpstops aren't worth pulling from the w123 (sorry)
The ac controls and headlight switch work.
Oil filter housing and cooler lines are intact and in good shape.
I didn't have time to pull these parts this weekend but you guys want them I will pull them ASAP.
