STD Other Projects w124 om606 The build tho more power
  • 2 Vote(s) - 1 Average
g kosters
01-02-2013, 12:28 PM #1
hey im new tho std but have spend lots of time reading projects of other members
and its about time tho work on a own stdTongue
i have a w210 with the om606 as donor
and the car where it goes in tho is a w124 260e
pics: wil come but first need tho make progressBig Grin
greetz gkosters
g kosters
greetz gkosters
TheDon
606 Power!!
247
01-03-2013, 01:03 PM #2
Take pics of the throttle linkage set up you make please!
TheDon
g kosters
01-07-2013, 06:52 PM #3
will do that when im there still need a ip for the om606
but have but me a v8, how do you call it swaybar?
are there choises within mechanical pumps for a 0m606?
and still thinking of wich trannsmision i should use
in the meantime im preparing the w124 for the 606
g kosters
Ksteen2
01-10-2013, 04:35 AM #4
all IP's thats mechanical has a 5,5mm element originaly, the original OM606 pump has 6mm.
so it's no biggie to use wich pmp you selv would like, off cource it is a positive side if u get a 7,5mm pump done by some finns or dieselmekken, then you should see some power Wink
reagarding tranny, automatic its 722.6, probably the one thats in the W210.
if you want a stick shift, use a BMW ZF with welded bellhousing, or just go fro the CDI 6 speed tranny from a W210 220cdi Wink
Ksteen2
g kosters
01-15-2013, 04:30 AM #5
hey
im looking for an ip and read on this site that a rs203 pump wouldt be the best platform tho start of ,but on wich engine is it installed my local
dealer couldt find nothing about it
if i have a complete number of the ip i can give him the info
and some pictures of the build wil post that thoday :p
g kosters
hey
roycem3
01-30-2013, 12:13 AM #6
(01-15-2013, 04:30 AM)g kosters hey
The RS203 comes in the om606NA (non turbo) from 95--97.
"PES 6M 55C 320 RS203". You need to use an external ALDA for your turbo application. I spoke to Dieselmeken from Sweden and he has the external ALDA kit. Send me a PM if you want more info.
roycem3
