glow plug relays? after glow
My 1987 300SDL fried the glow plug relay cranking it over to long with a low battery. Now the glow plug light wont light up at all. all of the plugs are new!
What is the best factory glow plug relay with the longest after glow time
that will plug in? model or part number?
I thought I read some where that the 350sd or newer 300d om606 would work
I'm looking to get a used one for cheap to get her running again. It has always been a bear to start in cold weather If I don't run the glow plugs a few times. After glow is a must for this beast with a cracked head to start on all cylinders.
Thanks Will
P.S. still working on the new house. so the 6spd swap is on hold till later this summer I hope
