STD Tuning Engine Monster Hybrid 6 Cyl IP
OM616
10mm MW
574
01-27-2013, 12:58 PM #1
Literally just had a thought, so I thought I would put it out there and see how off my rocker I am.
For those running 606 engines they are up against a hard wall in regards to element size, and there for delivery duration, at high rates of delivery.
What if a new hybrid pump was made that used the cam of an M pump and the elements of a MW or P pump? That would allow up to 13mm elements to be run on a 606! Either the RW or RSF governor could be used as well.
Now I understand that the cost of such a pump would restrict its use to only a couple of cars, but they would have all the fuel they would want, lol.
OM616
EDH_Performance
01-27-2013, 01:32 PM #2
Sounds like something for meBig Grin
But there are 8mm m-pumps that delivers 275cc and that is enough to make over 800 hp on a OM606Wink
EDH_Performance
01-27-2013, 02:07 PM #3
P7100 pumps with 12mm elements put out an easy 650cc with no major modifications. I think 13mm would be a little large for any little engine.
OM616
10mm MW
574
01-27-2013, 02:13 PM #4
(01-27-2013, 01:32 PM)EDH_Performance Sounds like something for meBig Grin
Yes, however a larger element will allow you to deliver the same 275cc in less time.
OM616
lpumb3
617 300sd
141
01-27-2013, 03:59 PM #5
In teresting , a stroke of luck would have an additional pump on my bench.
To the sweet tune of part # PES5M55C320 RS108
011 34391814
0 400 075 991
617 070 4301 ER0002
Ill have my girl show me how to put up pics latrer
lpumb3
011 34391814
0 400 075 991
617 070 4301 ER0002
dieselmeken
01-28-2013, 06:17 AM #6
Wish it, dream it, do it, but for what purpose? I know what cost there is to just develope a nice element that works OK, ALDA etc, Who would buy it for ex 10000 USD?
dieselmeken
lpumb3
617 300sd
141
01-28-2013, 08:08 AM #7
lol , worlds fastest idi benz?
i love the idea , OM i think in PM i had asked about cams for the pump, or for the lift pump?
as far as your knowledge of helix angles and there relation to cam duration overlap , could in your (or dieselmekens ) endeavors to make a better element helix. design a camlobe profile to meet or exceed your goals?
the old school guys could take your cam , (idk the process) spray weld material onto the cam to build up the lobe then grind it back to the new desired specs.
what are the major differences between the m-mw pumps cams ?
ill watch this for theory but im missing 1 cyl to be relevant
This post was last modified: 01-28-2013, 08:11 AM by lpumb3.
lpumb3
HoleshotHolset
01-28-2013, 10:52 AM #8
Or we could use a 12-cylinder pump on a 6-cylinder engine. It has been done plenty of times with dual feed injectors, but good luck driving it on the street.
Beers,
Matt
'07 W211 OM642
HoleshotHolset
Beers,
Matt
'07 W211 OM642
OM616
10mm MW
574
01-28-2013, 12:35 PM #9
(01-28-2013, 06:17 AM)dieselmeken Wish it, dream it, do it, but for what purpose? I know what cost there is to just develope a nice element that works OK, ALDA etc, Who would buy it for ex 10000 USD?
For what purpose?... Why do hot sauces keep getting hotter? lol... Because it can be done lol.
Actually, the only part that has to be made is the pump case. Stock M pump cam, off the shelf MW or P elements, Stock rack parts, Stock turbo governor, ect.
OM616
Mark_M
01-28-2013, 12:46 PM #10
You mean like this?
[Image: 11.jpg]
from http://www.herlevi.fi/products.htm
This post was last modified: 01-28-2013, 12:46 PM by Mark_M.
Mark_M
You mean like this?
[Image: 11.jpg]
OM616
10mm MW
574
01-28-2013, 12:55 PM #11
That is a P pump housing, but it's cost would be very close if not the same as a MW style housing.
Any idea how much that one costs?
OM616
01-28-2013, 01:05 PM #12
Is the timing the same on a P pump? Couldn't you just make a crazy adapter to fit a P pump?
Mark_M
01-28-2013, 01:11 PM #13
Haven't a clue but I suspect if you have to ask you can't afford it. When custom delivery valves are a €1000 I imagine a whole custom pump will be eye watering!
Mark_M
OM616
10mm MW
574
01-28-2013, 01:38 PM #14
(01-28-2013, 01:11 PM)Mark_M Haven't a clue but I suspect if you have to ask you can't afford it. When custom delivery valves are a €1000 I imagine a whole custom pump will be eye watering!
I have my own machine shop, so I have a good idea what it would run to have a billet housing made, but it is always nice to know what the market will support, after all they made it for someone lol
(01-28-2013, 01:05 PM)Simpler=Better Is the timing the same on a P pump? Couldn't you just make a crazy adapter to fit a P pump?
Not really, it would be a total cluster and the governor is designed for slow speed operation compared to the MB engine speeds.
This post was last modified: 01-28-2013, 01:41 PM by OM616.
OM616
Ksteen2
11-20-2013, 03:43 AM #15
I would love to see some resaults from this Smile
1#
Volvo 940 estate 1995
Originaly a d24tic
6speed cdi box
4,5" humongus cooler
Please wait, loading boost
Ksteen2
1#
Originaly a d24tic
6speed cdi box
EDH_Performance
11-20-2013, 05:25 AM #16
Bosch A-pump 9.5mm elements in a M-pump^^
EDH_Performance
_siim_
W201STD
21
11-21-2013, 03:34 AM #17
(01-28-2013, 01:38 PM)OM616
Engine power: hp/rpm 2500/5550
Torque: Nm/rpm 3500/4800
Cylinders: 6 cyl / capacity
Fuel: Diesel
Injection Pump: Diesellandia
Billet 17mm
Turbocharger: Diesellandia ball bearing turbocharger 8,0 bar
Intercooler: Water cooled
390 celsius - 25 celsius
Water Injection: 7 nozzles / 40 bar
This post was last modified: 11-21-2013, 03:35 AM by _siim_.
Black beast....
_siim_
Fuel: Diesel
Billet 17mm
Black beast....
erling66
SuperDieselVan
294
11-24-2013, 03:37 PM #18
What about a Bosch pes6mw100/x? Will it fit a 606 with an adapter? Should provide all the fuel you will ever need with those 10mm elementsSmile Idle will probably be an issue for those who care about thatTongue
HuhCoolTongue
erling66
HuhCoolTongue
11-26-2013, 04:02 PM #19
(01-28-2013, 10:52 AM)HoleshotHolset Or we could use a 12-cylinder pump on a 6-cylinder engine. It has been done plenty of times with dual feed injectors, but good luck driving it on the street.
Beers,
Matt
YESS!!!!!!!!!
Beers,
Matt
YESS!!!!!!!!!
11-27-2013, 08:59 PM #20
Beers,
Matt
Are they technically called "dual feed"? Everytime I hear dual feed I think of the injector body itself having two passageways around the needle valve instead of one.
In DI injectors at least
Beers,
Matt
