STD Tuning Engine Bailing on the Vacuum Pump
Joaquin Suave
02-15-2013, 02:16 PM #1
I'v converted my Jeep Scrambler to a Hydro-Boost brake system, thus have no need for the vacuum pump on my motor (om602 2.9l).
Should I just cap it off or should I remove it and machine a cover plate to replace it with????
Joaquin Suave
02-15-2013, 03:43 PM #2
I would remove it if it isn't being used anymore. Are you using the vacuum shutoff still?
Joaquin Suave
02-15-2013, 04:33 PM #3
Quote:Are you using the vacuum shutoff still?
VE pumps have a solinoid shut-off.
Joaquin Suave
02-15-2013, 04:49 PM #4
I would fabricate a blockoff plate and sell the pump. Wasn't aware that you have a solenoid on/off
