STD Tuning Engine WTB/WTT for 617 M pump parts
Austincarnut
03-10-2013, 10:03 AM #1
I'm looking for 617 M pump lines, lift pump and throttle linkages. I have spoken to a few of you already and would just like the word out there as these parts are a little harder to come by. Any help will be appreciated, I have a lot of parts for trade and plenty of rust free sheet metal.
Austincarnut
lgreeley83
Mr. Rumbles
03-10-2013, 10:16 AM #2
There is a decent line waiting for stuff like that. Good luck though.
lgreeley83
poleshady
05-19-2013, 04:37 AM #3
what is the going rate for an M pump and the hard lines? i have one not sure if i should hold onto it or sell it
poleshady
Austincarnut
05-19-2013, 07:35 AM #4
(05-19-2013, 04:37 AM)poleshady what is the going rate for an M pump and the hard lines? i have one not sure if i should hold onto it or sell it
Whatever you can get, I found all of what i need
Austincarnut
Njdub
05-19-2013, 12:13 PM #5
I am interested if you would like to sell the lines and everything.
Njdub
lgreeley83
Mr. Rumbles
05-19-2013, 08:24 PM #6
BTW. I just test fist m pump linkage on my car today. The shaft from firewall to linkage is the same. I thought I read somewhere that 240d linkage might be similar but its been a little.
I say test fit because the original bushings on m pump linkage fell apart as soon as I applied throttle. I will figure something out.
Also I was trying it on non M pump, geometry was a little off and some slight rubbing on glow plug wires but I believe it would have worked.
Lines, good luck......
lgreeley83
