Which front sway bar for w201 with OM605 & four piston brakes?
Quote:W124 V8 Front Swaybar 'Trimmed' to fit along with W124 V8 'hooks' hung backwards with alittle trimming so now the swaybar clears the engine's oil pan
Well, depends on what your trying to accomplish. Main thing is probably only a 2.6 or 2.5 Turbo with be the only bolt-on option. With a little modding you can use W124 sway bars see my W201 Project Thread but I'm using a OM603 so there's sway bar clearance issues and I have to use a W124 V8 sway bar.
(03-24-2013, 10:14 AM)Kozuka Well, depends on what your trying to accomplish. Main thing is probably only a 2.6 or 2.5 Turbo with be the only bolt-on option.Something to cope with the weight, the turbo 605 & 722.6 are a little heavier than the current 602 & 722.4, also it will be able to brake a lot harder than it could with standard 190d brakes so I need something to help cope with brake dive.
(03-26-2013, 03:04 AM)Kozuka These things could be improved with a higher spring rate, cut r129 SL500 springs might be what your looking for.
If you're worried about body roll and dive, I'd start with spring rates. I know it's $$$ but have you considered the Ground Control coilover suspension stuff? You pick your spring rates.
http://www.ground-control-store.com/prod...php/CA=289
