bmw 530d 5speed gearbox to om606
Hi I'm trying to get my BMW box mated up to the 606, have my clutch setup almost sorted,. Using a sprung type (not diaphrag) clutch from thwaites dump truck with uprated springs and custom twin plate setup. I've the box stripped and plan is to lengthen the spiggot shaft then make adaptor plate to mate gearbox to engine has anyone tryed this setup??
Cheers Dave
(04-25-2013, 05:01 PM)diesel dave Hi I'm trying to get my BMW box mated up to the 606, have my clutch setup almost sorted,. Using a sprung type (not diaphrag) clutch from thwaites dump truck with uprated springs and custom twin plate setup. I've the box stripped and plan is to lengthen the spiggot shaft then make adaptor plate to mate gearbox to engine has anyone tryed this setup??
Cheers Dave
Cheers Dave
(04-26-2013, 11:31 AM)swecias(04-25-2013, 05:01 PM)diesel dave Hi I'm trying to get my BMW box mated up to the 606, have my clutch setup almost sorted,. Using a sprung type (not diaphrag) clutch from thwaites dump truck with uprated springs and custom twin plate setup. I've the box stripped and plan is to lengthen the spiggot shaft then make adaptor plate to mate gearbox to engine has anyone tryed this setup??
Cheers Dave
this is how i made:
http://www.per4m.lt/forum/download/file.php?id=3370
http://www.per4m.lt/forum/download/file.php?id=3369
Cheers Dave
this is how i made:
I Used mb om604 flywheel, duoble plate bmw presure spring, and bmw ceramic disk
http://www.per4m.lt/forum/download/file.php?id=3329
http://www.per4m.lt/forum/download/file.php?id=3328
http://www.per4m.lt/forum/download/file.php?id=3327
http://www.per4m.lt/forum/download/file.php?id=3332
http://www.per4m.lt/forum/download/file.php?id=3330
http://www.per4m.lt/forum/download/file.php?id=3337
ah OK.. thinking about it my flywheel is from SM conversion from a Sprinter.. I had forgotten there was none for 606.
I have been measuring again tonight though.. ID of both 606 and GS6-52DZ gearbox are 32.5mm so MB flywheel and starter ring fit comfortably inside.. I am thinking that a adapter plate is a real possibility, however I am unsure what the effect of say +25mm depth of plate will be on distances for clutch plate to flywheel and pilot bearing shaft. I guess possibly flywheel can be set further out on crankshaft to compensate.. I must investigate this.
(04-30-2013, 04:33 AM)fcp One thing you might be able to help me with - I am missing the pilot bearing shaft (the short shaft that goes into the end of the spline'd input shaft and pilot bearing in flywheel).
I can't seem to get one from MB (they supply no gearbox spares at all unbelievably) and I guess I will have to fabricate; I wondered if you could measure the one you have (length/ diameter) and take a photo for me if its anything other than a straight shaft?
