diff with LSD to w201
I'm sure theres a .pdf of an Excel spreadsheet somewhere on gsxr's (aka AMGDave) website:
http://www.w124performance.com/images/W124_diffs/
Only the 2.3-16 is bolt-on lsd for the w201, it can be hodge-podged with r129 & w124 & w210 parts to change ratios.
Thing is who do you get to rebuild the clutches in the diff? There we're some one off 'phantom grip' style lsd friction plates that we're made for open diffs for the w201. I had one, haha..
Here's that spreadsheet. Great resource
http://www.w124performance.com/docs/mb/o...ntials.pdf
More stuff
http://www.w124performance.com/docs/mb/W...trofit.pdf
What gear ratio are you looking for? The only # that I know of for a W201 complete LSD assembly is a 3.27 LSD is 2013507820 with ABS and 2013501003 without ABS. You will ruin your car with this ratio. To my knowledge, the only way to keep diesel-friendly gearing and have an LSD will require installing an LSD carrier into your rear diff assembly. The part number for this carrier is in the spreadsheet I linked to.
