STD Tuning Engine Starting 606 with automatic flywheel/flexplate
HaavardPYA
05-09-2013, 02:54 PM #1
Have someone tried to start an 606 with just the automatic flywheel on? Is this to light so that its harmful for the crank? Heard from the bmw guys that they dont recomend to start the bmw diesels with anything that the manual flywheels attached.
HaavardPYA
hansendk
05-09-2013, 06:51 PM #2
dont do it tried it on a Cummins B engine while dyno it, destroyed 3 automatic belt tensioner big problems at idle but if you can mount something else its ok, i solved the problem by using a om352 flywheel just as weight and we dynoed the engine with no problems
hansendk
HaavardPYA
05-10-2013, 12:00 AM #3
It is just for start up. So there will be no big rpm. But ill change itSmile
HaavardPYA
hansendk
05-10-2013, 01:54 AM #4
yes but the problem is comming in low RPM. not high you can do for a short testrun but i wouldent do it this happendt 5 years ago and i still remember like yesterday i am working engine reman and we test over 100 diesel engines every year mostly MAN, Mercedes and MTU but it your choise.
hansendk
HaavardPYA
05-10-2013, 06:16 AM #5
Ok. I will install a 601 wheel.
HaavardPYA
erling66
SuperDieselVan
294
05-11-2013, 03:46 AM #6
I have done it several times and never had a problem. Other guys on this forum have done the same. Maybe we were luckySmile or the Mercedes 606 is so well build that the vibration is no problem?
HuhCoolTongue
erling66
HuhCoolTongue
HaavardPYA
05-11-2013, 08:07 AM #7
Started it today, no problemSmile
HaavardPYA
